Hello,
Could someone post their tool library file file from vrturning for a Novaturn lathe for the standard tools - e.g. roughing, parting, parting, int. threading, centre drilling, drilling, ext. threading, finishing?
It would be handy to compare the angles and i sizes i have set against someone elses.
Many thanks,
David.
Tool Library for Novaturn
Thanks even the config for a couple of tools...
...would be very useful to me
thanks
david.
thanks
david.
Not sure how much use these are
(the tools are all library defaults - just the offsets have been changed in order to cut our test part)
Tool Library File vrturn.ttd:
Tool (turret) file Default.tft :[Roughing Tool]
Type=0
Class=0
Tool Orientation=8
Tip Orientation=3
Colour=255
Nose Radius=0.5
Maximum Tool Life=50
Current Tool Life=-1
Tip Angle=60
Tip Clearance=-10
Tip Size=12
Length=60
Width Diameter=12
[Grooving Tool]
Type=2
Class=0
Tool Orientation=8
Tip Orientation=3
Colour=16711808
Nose Radius=45
Current Tool Life=0
Tip Angle=6
Tip Clearance=-45
Tip Size=6
Length=60
Width Diameter=12
[Internal Thread]
Type=1
Class=1
Tool Orientation=7
Tip Orientation=6
Colour=16384
Nose Radius=0
Maximum Tool Life=0
Current Tool Life=0
Tip Angle=60
Tip Clearance=0
Tip Size=9
Length=60
Width Diameter=12
[Boring Bar]
Type=0
Class=1
Tool Orientation=7
Tip Orientation=2
Colour=16744576
Nose Radius=6.88
Maximum Tool Life=0
Current Tool Life=0
Tip Angle=60
Tip Clearance=0
Tip Size=12
Length=60
Width Diameter=12
[Center Drill]
Type=4
Class=1
Tool Orientation=7
Tip Orientation=7
Colour=65535
Nose Radius=0
Maximum Tool Life=0
Current Tool Life=0
Tip Angle=52
Tip Clearance=-45
Tip Size=10
Length=80
Width Diameter=19
[External Thread]
Type=1
Class=0
Tool Orientation=8
Tip Orientation=3
Colour=16711680
Nose Radius=0
Current Tool Life=0
Tip Angle=60
Tip Clearance=-45
Tip Size=12
Length=60
Width Diameter=12
[Finishing Tool]
Type=0
Class=0
Tool Orientation=8
Tip Orientation=3
Colour=4227327
Nose Radius=0
Current Tool Life=0
Tip Angle=45
Tip Clearance=-15
Tip Size=12
Length=60
Width Diameter=12
[Drill]
Type=3
Class=1
Tool Orientation=7
Tip Orientation=7
Colour=32768
Nose Radius=0
Current Tool Life=0
Tip Angle=90
Tip Clearance=0
Tip Size=15
Length=80
Width Diameter=12
[Parting Off Tool]
Type=2
Class=0
Tool Orientation=8
Tip Orientation=3
Colour=8421376
Nose Radius=0
Current Tool Life=0
Tip Angle=60
Tip Clearance=-45
Tip Size=4
Length=60
Width Diameter=12
[Pusher]
Type=5
Class=1
Tool Orientation=7
Tip Orientation=7
Colour=4259584
Nose Radius=0
Current Tool Life=0
Tip Angle=60
Tip Clearance=0
Tip Size=15
Length=60
Width Diameter=12
TipIndex=18
Attach_X=34
Attach_Y=22
0_X=23
0_Y=35
1_X=23
1_Y=30
2_X=23
2_Y=30
3_X=32
3_Y=30
4_X=32
4_Y=30
5_X=32
5_Y=27
6_X=32
6_Y=27
7_X=32
7_Y=27
8_X=32
8_Y=27
9_X=29
9_Y=27
10_X=29
10_Y=27
11_X=29
11_Y=22
12_X=40
12_Y=22
13_X=40
13_Y=27
14_X=37
14_Y=27
15_X=37
15_Y=30
16_X=45
16_Y=30
17_X=45
17_Y=35
18_X=34
18_Y=35
[Global]
Current Tool=5
[1]
X=-88.4
Z=-128.1
Radius=0
[2]
X=0
Z=0
Radius=0
[3]
X=0
Z=0
Radius=0
[4]
X=0
Z=0
Radius=0
[5]
X=-81.09
Z=-134.18
Radius=0
[6]
X=0
Z=0
Radius=0
[7]
X=0
Z=0
Radius=0
[8]
X=0
Z=0
Radius=0
[Tool1]
Tool Name=Roughing Tool
[Tool2]
Tool Name=Finishing Tool
[Tool3]
Tool Name=Drill
[Tool5]
Tool Name=External Thread
