G96 Constant surface speed not working correctly for me.
Posted: Mon 04 Sep , 2006 21:16 pm
The unit is a Novaturn 99 vintage. fully updated firmware and VR software.
When programing a G96 CSS it works perfectly on the first tool no matter what tool number or offset but on the second tool it runs extremely slow (like 150rpm)
Any combination of tools or offsets do this. Here is an example.
First G96
N180 G96 F0.008 S200 (in SFPM) works perfectly
runs through code
Second tool
N1070 (END TOOL)
N1080 G00 G40 G20
N1090 G28 U0.
N1100 G28 W0.
N1110 M00
N1120 (MDJNR 12-4B RIGHT)
N1130 T0101
N1140 G96 F0.008 S20
Runs super slow. I can program all succesive tools in RPM with a G97 and then works fine, but its like the controller cannot update itself after the first G96 that comes after an offset/tool change.
Kinda of an odd question to add to this. This unit was brand new when I purchased it and has been updated to the latest firmware and VR turning but it is still very quirky. For instance, sometimes when zeroing the Z axis it holds onto some number from before and wont completely zero. If I disconect the machine in VR turning and reconect it zeros right out. That is just one of multiple quirks I have found. Is there some way to reset the controller or something? Is there a newer controller that is more reliable that I can purchase?
I thank you for any ideas you may have about the G96 issue
First G96
runs through code
Second tool
N1070 (END TOOL)
N1080 G00 G40 G20
N1090 G28 U0.
N1100 G28 W0.
N1110 M00
N1130 T0101
