// v1.32 - 25/1/2013 - Fix to G81 cycle so that it is modal, eg G81 Z-10; Z-20; Z-30 will remain in G81 drilling mode until G0/1/2 or 3 is programmed
// v1.32 - 31/1/2013 - Fix to Print > offsets to show the X offset value as a diameter if not in RadiusProgramming mode
// v1.32 - 19/3/2013 - added Turn370, nb Now, if Tool Change Auto type is set to -1 then VRT and Mint uses the nvLong[19] location to determine turret type.
// v1.32 - 19/3/2013 - if mint files per machine don't exist, the file missing error can be removed by adding BigMint2.mnt to the .ini file: Mint File=C:\Program Files\Denford\VRTurning\BigMint2.mnt
// v1.32 - 21/3/2013 - fix so Toollist.current is updated when the control panel Tool number changes (eg. when homing and turret changes to tool 1 without a Tool call)
// to do with error where tool editor opened up with wrong tool showing.
// v1.32 - 21/3/2013 - changes in control panel - button is now spindle on/off
// v1.33 - 24/6/2013 - fix to TP135 toolchange to compensate for bouncing strobe switch
Check here to download the latest version of all software:
VR Turning v1.33 released 25th June 2013
- dixonsca
- CNC Apprentice
- Hardware/Software: Denford Magnum router. (now upgraded to a 3d router using retrofit kit macmotion controller and upgraded stepper motors)
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
Makerbot Replicator 2
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d - Location: Bradford
Re: VR Turning v1.33 released 25th June 2013
Will installing the updates re-set VR Turning back to its default settings?
In what respect?
You can backup and save offsets and datums first.
You could also print the values.
I think most settings would be set back to default.
