Thread cutting on Mirac lathe
Help and advice for Denfords lathe control software VR Turning.
Wheezy
Post by Wheezy » Thu 13 Nov , 2008 0:18 am
I'm having problems getting a good quality thread and I've been playing about with it, but to no avail. I was wondering if the spindle speed and feedrate overide controls need to be on a certain setting to ensure that they are synchronised, or does the software take care of that automatically?
I've left the tool data set on a default setting and wondered if I need to change anything there?
Any help gratefully received,
Wheezy
Post by Denford Admin » Mon 17 Nov , 2008 11:29 am
The feed is locked into the speed of the spindle, so override should have no effect whilst the thread cut is in progress.
What is the problem with the threads ? Is the surface finish poor ?
The Mirac should give you good results as long as everything is tight, tool sharp and surface speed correct for the material etc...
