// v1.29 - fix to Carousel and offsets form to allow you to type in offset values properly
// v1.29 - change to Carousel and offsets form to allow editing of any offset available - datum set buttons only available on current tool though
// v1.29 - added to Carousel and offsets form measured difference form to let you input measured sizes against programmed and it will alter the offset accordingly
// v1.29 - added menu File>Print>Offsets to let user print work and tool offsets out
// v1.29 - fix for workoffsets - didn't update tool offset if tool changed while workoffset window was open.
// v1.29 - added measured/actual difference buttons to workoffset as well as tool offsets.
// v1.29 - bug fixes to G42 cutter comp
// v1.29 - changes to BigMint2 so that M03/M04 wait for spindle to get to speed properly (within 10%)
// v1.29 - updated to new Installation - any issues to do with files not being found or registered (.ocx's) will be down to this
Check here to download the latest version of all software:
VR Turning v1.29 released 24th Aug 2012
Re: VR Turning v1.29 released 24th Aug 2012
I am using V1.27 with my Novaturn (Smartstep/3 board) and this version has the Security code in the INI file
Will V1.29 work for me?
yes- I've just double checked that version with a Flash code in vturn.ini, no seckey.tff file and it still works OK
Hi Thanks
Sorry to trouble you, its OK got very confused with all the versions of software on the PC!!
