I have a denford plus printer that will not connect to the computer, it will initialize from the switch on the front, all the axis home ok and the led changes to green.
This is the same on a PC and a Mac that has been used previously with no problem, USB lead has also been replaced.
I believe that the daughter board is at fault, how do I obtain a replacement, I looked at the available parts in your online shop but they are not listed.
Any help would be appreciated.
Denford/UP plus printer
- bradders
Re: Denford/UP plus printer
Can you contact Denford's tech, on 01484 728000
