Triac Fanuc 24v power supply
Posted: Tue 11 Feb , 2025 23:05 pm
by Dougal
The above has failed. Only details I can see is the manufacturer Lambda, now TDK-Lambda I think. It is clearly just a 200v/24v switching power supply, but should I be looking for anything in particular amp wise. According to the wiring diagram it only supplies the ESR circuit.
In the meantime, any reason not to temporarily use an adjustable bench power supply?
Thanks.
Re: Triac Fanuc 24v power supply
Posted: Tue 11 Feb , 2025 23:21 pm
by Dougal
Or, indeed, would anyone have the Denford spec for this?
Posted: Wed 12 Feb , 2025 14:17 pm
by Dougal
Oops! 110/24v.
Connected bench power supply and the current shows 1 amp, so anything over 30w should be fine. Smallest available seems to be 60w and input ranging from 110-240v.
