NextMove ST: Controlling SOUT via PWM to bottom card?
Posted: Mon 25 Jan , 2016 3:32 am
by summetj
I have removed the top card of the NextMove ST board from a MicroMill 2000 (Dispatch Date 2005) and connected to the step/direction pins and home/ESTOP/SGR via a parallel port break out board successfully using Mach3 and LinuxCNC.
Lots of details here:
https://www.summet.com/blog/tag/micromill/
I would like to control the SOUT (spindle out, 0-10 volt isolated voltage output for the KB spindle control board) via a PWM signal from the breakout board, but I don't know where it connects into the optoisolator. I can't find anything on the 96way connector that looks good (demand-0 didn't work when I connected it to +5v) and was wondering if it should connect to a pin on the OTHER connector (with 2 columns instead of 3).
Any input would be appreciated.
Thanks,
Jay
Re: NextMove ST: Controlling SOUT via PWM to bottom card?
Posted: Wed 27 Jan , 2016 21:36 pm
by TDIPower
Brilliant info!! I was wondering about the noise on the spindle motor as it was suggested that some of the issues I have with the units at work where it looses position could be down to aging motors and more noise. I was wondering about adding suppression to the motor.
Posted: Sun 31 Jan , 2016 3:22 am
by summetj
TDIPower wrote:Brilliant info!! I was wondering about the noise on the spindle motor as it was suggested that some of the issues I have with the units at work where it looses position could be down to aging motors and more noise. I was wondering about adding suppression to the motor.
I was able to just turn on software debouncing and that fixed my noise problems. You could also try and re-route the home/limit switch wires away from the spindle motor drive wires inside the case.
Posted: Sun 31 Jan , 2016 3:24 am
by summetj
For anybody looking to do PWM control via the bottom board (Balfor Next Move ST SOUT signal) I figured out how to do it.
https://www.summet.com/blog/2016/01/29/h ... d-control/
There is no pin that exposes the correct input signal line, so you have to solder a wire directly to pin 3 on the optocoupler (and remove R29, a surface mount resistor), but it does allow a parallel port breakout card to drive the KB spindle motor controller via a PWM signal.
