Help VMC TRIAC
- CNC Apprentice
- Hardware/Software: VMC TRIAC with ATC
Re: Help VMC TRIAC
This is my file fanucmd.go:
IBM.RS2 2
$3F8 4 COM1
$3E8 4 MACHINE
DENFORD.KBD 1
18.2 $2F8 3
EGA.CRT 0
FANUCMD.APP
when I launch the program fanucmd.exe, pc load the drivers, but it all hangs out with the file fanucmd.app
desk-top tutor in com1
machine in com2
WE HAVE CHANGED WITH THIS:
IBM.RS2 1
$2F8 3 MACHINE
DENFORD.KBD 1
18.2 $3F8 4
EGA.CRT 0
FANUCMD.APP
have you suggestions?
IBM.RS2 2
$3F8 4 COM1
$3E8 4 MACHINE
DENFORD.KBD 1
18.2 $2F8 3
EGA.CRT 0
FANUCMD.APP
machine in com2
IBM.RS2 1
$2F8 3 MACHINE
DENFORD.KBD 1
18.2 $3F8 4
EGA.CRT 0
FANUCMD.APP
Re: Help VMC TRIAC
Have you put the EPROM from the old card into the new card ?
What does the LED light up with when powered on ?
- CNC Apprentice
Re: Help VMC TRIAC
Yes I have put the old eprom in a new card and the LED light up with when powered on write 8.
Re: Help VMC TRIAC
From my understanding your old .go file shows:
IBM.RS2 2
$3F8 4 COM1 - software uses COM1 ($3F8) - I think this will be for dripfeed from another pc - maybe not connected?
$3E8 4 MACHINE - COM3 ($3e8) for the machine connection - to the eurocard
DENFORD.KBD 1
18.2 $2F8 3 - use COM2 for the Tutor keypad
EGA.CRT 0
FANUCMD.APP
So I would say you need to change it to this to swap Tutor and machine (as we know tutor was working)
So tutor in COM3 and machine in COM2:
IBM.RS2 2
$3F8 4 COM1
$2F8 3 MACHINE
DENFORD.KBD 1
18.2 $3E8 4
EGA.CRT 0
FANUCMD.APP
IBM.RS2 2
DENFORD.KBD 1
EGA.CRT 0
FANUCMD.APP
IBM.RS2 2
$3F8 4 COM1
$2F8 3 MACHINE
DENFORD.KBD 1
18.2 $3E8 4
EGA.CRT 0
FANUCMD.APP
- CNC Apprentice
Re: Help VMC TRIAC
We've done several tests, but without success.
Can I start the machine with a single COM?
- CNC Apprentice
Re: Help VMC TRIAC
I tested the COM1 and COM2 on my PC and I am ok.
I put the Machine in COM1 and Tutor in COM2, the same error.
This is the file .go it's ok?
IBM.RS2 2
$3F8 4 MACHINE
DENFORD.KBD 1
18.2 $2F8 3
EGA.CRT 0
FANUCMD.APP
I do not know what to do!
Help me please...
IBM.RS2 2
$3F8 4 MACHINE
DENFORD.KBD 1
18.2 $2F8 3
EGA.CRT 0
FANUCMD.APP
Help me please...
Re: Help VMC TRIAC
Yes that .go file looks ok for Machine in COM1 and tutor in COM2
There must be an issue with the RS232 cable or the card - unfortunately we have no way to test the cards here now
Have you double checked the cable from PC to Baldor card ?
From 9-pin to 9-pin the connections should match the diagram shown here:
viewtopic.php?t=544
viewtopic.php?t=544
- CNC Apprentice
Re: Help VMC TRIAC
I can not understand the pattern of the post.
the image refers to female cable seen from outside.
Re: Help VMC TRIAC
I've added another image to the post which should explain...
viewtopic.php?f=54&t=544
- CNC Apprentice
Re: Help VMC TRIAC
Thanks but maybe I expressed myself badly.
Mean to the electrical diagram of the cable.
However I did I asked a fellow electrician
Re: Help VMC TRIAC
Ignore the shape of the connector in the diagram- it is not as seen in real life. - just use the numbers stamped next to each pin of the connector to confirm the cable you have is ok (or make up the 9-9way as shown)
I will alter the diagram to show the connectors more clearly...
- CNC Apprentice
Re: Help VMC TRIAC
It's so much clearer, I try tomorrow.
Thank you very much.
- CNC Apprentice
Re: Help VMC TRIAC
Hello, built cable as pattern.
We launched the program with this file fanucmd.go:
ibm.rs2 1
3F8 $ 4 MACHINE
QDENFORD.KBD 1
18.2 0
EGA.CRT 0
FANUCMD.APP
I downloaded the file QDENFORD.KBD from your site and I put it in the folder
PC always shows the error <50> MINT controller disconnected
what advice?
ibm.rs2 1
3F8 $ 4 MACHINE
QDENFORD.KBD 1
18.2 0
EGA.CRT 0
FANUCMD.APP
what advice?
- CNC Apprentice
Re: Help VMC TRIAC
I still doubt that he spoiled the old card by replacing the battery, it's possible?
Re: Help VMC TRIAC
I would make sure the file is exactly like this:ibm.rs2 1
3F8 $ 4 MACHINE
QDENFORD.KBD 1
18.2 0
EGA.CRT 0
FANUCMD.APP
IBM.RS2 1
$3F8 4 MACHINE
QDENFORD.KBD 1
18.2 0
EGA.CRT 0
FANUCMD.APP
There is nothing else I can see wrong...
The original DOS, esMint, Mint328 EPROM is fitted ?
The RS232 cable from PC to Baldor is correct ?
The CARD lights up OK with 8 or L ?
It could be that the comport is faulty - can you connect the tutor to COM1 and does it still work in the software ?
If I wanted to try and test the card's RS232 I would:
Re-fit the new 2.1 EPROM that came with it.
Then download VRMilling version 2 from our website (>support>downloads) and install onto a windows XP PC with working RS232 ports.
Then run Mintman:
Then run the file: MintMan.EXE which is located in the VR Milling 2 installation directory (C:\Program Files\Denford\windmill)
Go to menu Setup -> Comm Port
Set the parameters to:
Baud: 19200
Parity: None
Data bits: 8
Stop bits: 2
Handshaking: none
Press OK
Press Upload Version button
If it connects to control OK and finds the mint version, you know the RS232 is OK on the card
If this dosn't work, the next solution is probably to get the USB card upgrade.
- CNC Apprentice
Re: Help VMC TRIAC
I did the test EPROM 2.1 with MintMan.EXE and everything is ok then the RS232 cable from PC to Baldor is correct, right?
I have put the old eprom in a new card and the LED light up whith 8.
How can I test the old EPROM?
How can I test This: esMint, Mint328 EPROM is fitted
The new card supports the old EPROM?
Thanks again.
Thanks again.
Re: Help VMC TRIAC
Yes everything outside the card sounds good if Mintman connected OK - did it upload the version of the 2.1 EPROM ok then ?I did the test EPROM 2.1 with MintMan.EXE and everything is ok then the RS232 cable from PC to Baldor is correct, right?
I don't know - it is before my time at Denford.How can I test the old EPROM?
The only way to be sure of EPROM is to create another, or compare it to the Hex files here: (both methods will need an EPROM reader/writer)
viewtopic.php?f=54&t=211&hilit=hex
I have just looked at that EPROM post and realised there could be an issue with the processor clock speed ... I think the old software used the clock speed to determine BAUD rate so if you have a 14Mhz compatible EPROM in a 16Mhz CPU board then it will never connect
Can you tell us what the clock speeds are on both of your boards ?
- CNC Apprentice
Re: Help VMC TRIAC
In the old card is installed the type processor KB12 and the silver clock crystal is 12MHz.
In the new card is installed the type processor KB20 and the silver clock crystal is 16MHz.
Exchanging the silver clock crystal from 16MHz to 12MHz this problem is resolved?
Re: Help VMC TRIAC
From looking at the EPROM post, someone else tried to fit 16Mhz crystal to an old card and it did not workExchanging the silver clock crystal from 16MHz to 12MHz this problem is resolved?
It would seem the processor on the card requires the matching clock speed.
The best solution is to blow a 512Kb EPROM with this file:
http://www.denfordata.com/downloads/dos ... 5_SJD5.HEX
Are you able to do this ?
If not I will look for an old EPROM with this version and send it to you
- CNC Apprentice
Re: Help VMC TRIAC
I wanted to try to change the 16 to 12MHz crystal and... It works!!!! YESSSSSS!!!!!
BUT?! It was too good to be true ...
The program starts but when I want to do the zero machine axes do not move.
The tutor works, I access to all menus but axes do not move.
