Novamill stepper driver issue
Hey guys I’m looking for some suggestions on troubleshooting my issue further.
I purchased this cnc with unknown issues. The x axis stepper was jittering so I swapped the output between the x and y. The same stepper works on the y axis so it doesn’t appear to be an issue with the motor. I don’t see any visible damage to the control board - any suggestions on what I could test with my fluke or something to narrow down the issue? Thanks!
I gambled on purchasing vr milling and afraid I might have made the wrong decision.
Re: Novamill stepper driver issue
I would try switching the drive to the motos by plgging the Y into the X and the X into the Y on the control card. You may have to remove the black key pins from the connector to do this.
viewtopic.php?f=54&t=1627.
Then by pressing the Y jog the X will move using the Y axis driver chip.
Use the secret home function and you will then be able to enter jog mode without homing up.
viewtopic.php?f=2&t=53#p104
Mr Magoo, Martin, Steve
