When the job is finished, I want to reconfigure the MicroMill for mill use and build or modify another small lathe for CNC use utilizing the spare Smartstep board. I found a spec sheet for it which says the following:
"The SmartStep/3 controller is a programmable computer designed specifically for the control of 3 independent stepper axes, integrated with a power supply and three small bipolar stepper drives, as a single compact unit. The drives provide 2A per phase at 40V in half step mode, which makes the system suitable for many frame size 23 and 34 motors.
18-28VAC input or 24-40VDC input, onboard power supply provides all other voltages required."
The stepper motors the mill came with are Vexta PH266-E1.2, 2 Phase, 1.2A, 5 ohms. I'd like to use more powerful stepper motors but not overload the controller, keeping in mind that it will be driving only 2 motors. I will also add additional mass/area to the driver heatsink and add a dedicated cooling fan based on the heat induced failure of the original. Do any of you experienced CNC/electronics gurus have any recommendations as to the stepper motor specs (voltage/amperage/ohms) I should look for that would be safe to use? I'm guessing the same controller was used on other Denford machines of that era and were equipped with more powerful stepper motors.
Thanks for looking,
Milton
