Zerocentre 4th axis
Any information regarding the Denford ZeroCentre ZeroTurn ZeroBore Fanuc CNC machines
GIBo
Hardware/Software: Fanuc om
Zerocentre 4th axis
Post by GIBo » Sun 16 Jun , 2013 22:40 pm
Fairly recently bought a Zerocentre after a bit of a strugle got it to reconise the computer and now running well.
It came with a forth axis having pluged it in I get nothing presume it need "switching on"somehow The machine is S No 8075555 ex Loughbourgh uni the 4th axis looks like its never been used any help gladly appreciated
GIBO
Re: Zerocentre 4th axis
Post by Denford Admin » Mon 17 Jun , 2013 9:20 am
There are lots of parameters related to the 4th axis but couldn't see any that enable it - couldn't see any 900 option bits either so it could be a standard feature (not an option)
I'd imagine there are some 8000 parameters to set for the 4th axis motor type, see this post:
viewtopic.php?f=33&t=2514&start=20
PS, I thought GIBO was some kind of acronym so googled it and found an interesting definition :shock:
http://www.urbandictionary.com/define.php?term=gibo
Post by Martin » Mon 17 Jun , 2013 17:02 pm
I remember retro-fitting the 4th axis several years ago. I would have documented the parameters at the time. It would have been recorded on a service sheet which may have been discarded in the move. I will not be able to check until friday but will let you know what I find.
I presume the motor parameters are set it just needs to know it has the 4th axis fitted.
GIBo
Post by GIBo » Mon 17 Jun , 2013 23:30 pm
Martin wrote:I remember retro-fitting the 4th axis several years ago. I would have documented the parameters at the time. It would have been recorded on a service sheet which may have been discarded in the move. I will not be able to check until friday but will let you know what I find.
Thanks Martin Think your right in saying the parameter are there only shows XYX on screen
GIBO
