TDS 1/1 Tailstock Lock
Posted: Thu 09 May , 2024 15:03 pm
by rasp
Hi, is anyone making the small 2 ball tailstock lock handle for the Viceroy TDS 1/1 GBS lathe or is there a drawing so I can make one myself.
Re: TDS 1/1 Tailstock Lock
Posted: Sun 12 May , 2024 10:28 am
by Nand
Not making one (the to-do list lengthens daily) but the tailstock barrel lock handle is part SP140. There are a couple of machining drawings for the part. If you return to the "Announcement Section", 6th up from the bottom is topic " Viceroy TDS 6WL Wood turning lathe manual & drawings". In the discussion,the 3rd response down is by Denford Admin, their last link "And here are the only WL scans I can find". Opening that link should display a 28Meg file, starting with WM100/404, If you scroll down to page 131 you should arrive at part SP140A . I think SP refers to something like standard part used on various machines. sorry I can't do links,.
Posted: Sun 18 Aug , 2024 1:32 am
by rasp
Thanks for the info, I made one and its finished off the tailstock.
