Acceptable chuck runout?
Posted: Mon 20 Jul , 2009 18:55 pm
Hi all.
Just a question that seems all to obvious to me, having bought an Axminster super precision chuck for my Denford wood lathe and using it for a while, I was not happy with the finish on the wood after sanding, it showed up a semi circle ring on both outside and inside surfaces!!
With this in mind I checked the runout on the spindle nose and register and found that to be within .001", but then checked the chuck and found that to be .005". I then spoke to the manufacturers and they said that is within their tolerences.
Am I asking too much or is that the norm for a £200 chuck with extra jaws etc.
Done a lot of reading and some amatuers make their own backplates etc and get results of +/- .001" but others say shop bought is .005".
I have tried all the usual things to correct runout, or am I being too fickle for work on a wood lathe???
I seem to find that a lot of people like to keep within .002", What do you think?
The second backplate that I purchased had a rounout of between .010" and .004" depending on which way the plate was bolted to the chuck!!! (iam still in talks with them).
Thanks in advance.
Thanks in advance.
