ML drawings for 5" TDS1 lathes
Post by Denford Admin » Mon 26 Jul , 2010 14:03 pm
ML100 ML105 ML110 ML115 A4 drawings scanned
Here are a lot of drawings for the smaller bits of Viceroy Lathes
ML115 drawings -
List of drawings:
ML115 scan index.txt
ML115 drawing list A4
(7.1 KiB) Downloaded 1300 times
and the drawing file:
https://www.denfordata.com/downloads/for ... 0scans.pdf (13Mb)
ML100 & ML105 drawings -
List of drawings:
ML100 scan index.txt
ML100 drawing list A4
(3.23 KiB) Downloaded 1213 times
https://www.denfordata.com/downloads/for ... 0scans.pdf (20Mb)
ML105 & ML110 drawings -
https://www.denfordata.com/downloads/for ... 0scans.pdf (17Mb)
BVS and MVS parts lists have been moved here: viewtopic.php?f=50&t=2960&p=10536#p10536
Andy B
Re: ML100 ML105 ML110 ML115 A4 drawings scanned
Post by Andy B » Tue 24 Jan , 2017 9:56 am
End drive (Change Wheel) Arrangement for Metric TDS 1/1 lathes (non-gearbox)
ML105_100C (CAD).pdf
End drive (non-gearbox)
(175.17 KiB) Downloaded 1407 times
Pete.
Post by Pete. » Tue 24 Jan , 2017 21:29 pm
Stud gears A-G for metric gearbox lathes.
ML 115 metric gearbox stud gears a to g.pdf
(2.34 MiB) Downloaded 1420 times
Andy B
Re: ML drawings for 5" TDS1 lathes
Post by Andy B » Fri 27 Jan , 2017 11:50 am
Nose thread and register data for 5" lathes (screw-on chucks)
ML_NOSEDATA.pdf
1 1/2" x 8TPI thread data
(144.8 KiB) Downloaded 1305 times
Pete.
Post by Pete. » Fri 27 Jan , 2017 12:54 pm
Thanks for the nose thread data Andy, that's a very handy reference to have.
Andy B
Post by Andy B » Tue 21 Mar , 2017 12:33 pm
4 drawings for cross-slide leadscrews - ML110/501A (English) and ML110/501B (Metric), ML100/514A (English) and ML100/514B (Metric).
Plus a drawing for the leadscrew nuts (3 different versions)
Edited to add further drawings.
ML100-514B.PDF
ML100/514B
(89.89 KiB) Downloaded 1298 times
ML100-514A.PDF
ML100/514A
(91.79 KiB) Downloaded 1312 times
ML100_512 bw.pdf
ML100/512 Cross slide nuts
(49.2 KiB) Downloaded 2873 times
ML110-501B.PDF
ML110/501B
(109.79 KiB) Downloaded 1299 times
ML110-501A.PDF
ML110/501A
(94.13 KiB) Downloaded 1229 times
Andy B
Post by Andy B » Wed 03 Apr , 2019 13:34 pm
Drawings for Leadscrews:
ML105/402 - Std 24" Imperial
ML105/402B - Long version (for 52"bed) Imperial
ML105/402C - Std 24" Metric
ML105/402D - Long version (for 52" bed) Metric
and the Bed Arrangement that shows these parts installed:
ML105/400
Edited to correct file comments.
ML105-400 5in S-C & Plain Lathes - Bed Arrangement.pdf
Bed Arrangement
(319.16 KiB) Downloaded 1093 times
ML105-402D.PDF
Long Metric Leadscrew
(103.07 KiB) Downloaded 1090 times
ML105-402C.PDF
Std Metric Leadscrew
(106.48 KiB) Downloaded 1049 times
ML105-402B.PDF
Long Imperial Leadscrew
(71.37 KiB) Downloaded 1047 times
ML105-402.PDF
Std Imperial Leadscrew
(96.17 KiB) Downloaded 1127 times
rpwilson
Post by rpwilson » Wed 03 Apr , 2019 15:14 pm
I knew you'd have the answer Andy!
How are you getting on with the Synchro, did you ever do the translation gears?
Richard Wilson
Andy B
Post by Andy B » Sun 07 Apr , 2019 21:08 pm
Toolpost drawings
ML119-1B.PDF
4-Way Toolpost (5.5")
(100.48 KiB) Downloaded 1082 times
ML119-1A.PDF
4-Way Toolpost (5")
(106.18 KiB) Downloaded 1070 times
ML119.PDF
2- & 4-Way Toolpost Arrangement
(83.18 KiB) Downloaded 1085 times
ML100-801B.PDF
2-way toolpost VS Lathes (5.5")
(106.75 KiB) Downloaded 1018 times
ML100-801A.PDF
2-Way Toolpost (5" Lathes)
(107.24 KiB) Downloaded 1012 times
ML100-801.PDF
Tool Post Base (Single Sided)
(78.34 KiB) Downloaded 1105 times
ML100-800.PDF
Toolpost Arrangement (Single sided)
(46.05 KiB) Downloaded 1063 times
Andy B
Post by Andy B » Sun 07 Apr , 2019 21:26 pm
... and an oddity..
It's numbering is part of the toolpost drawings... and looks like some tooling associated with their manufacture.
ML119-2A.PDF
Milling fixture
(106.79 KiB) Downloaded 1028 times
Andy B
Post by Andy B » Tue 15 Oct , 2019 20:50 pm
More drawings of small parts used on the 5" lathes, with some also carried over to the 280's
ML100/103 99T Sliding Gear 5in Viceroy Metal Lathe
ML100/144 Oilite Bush for 68T Gear 5in Viceroy Metal Lathe
ML100/111A Locknut 5in Metal Lathe
ML106/1 Cross Slide Thread Cutting Stop 5in & 280VS Lathes
ML100/118 Gear Shifter Shaft 5in Viceroy Metal Lathe
ML100/108A 38T Driving Gear 5in Viceroy Metal Lathe
ML100/111 Locknut (Special) 1-off
ML100/114 Eccentric 5in Viceroy Metal Lathe
ML100/131 Front Nose Cap 5in Viceroy Metal Lathe
ML100/132 Driving Pulley Plunger 5in Viceroy Metal Lathe
ML100/142 Lo Vo Light Fitting 5in Viceroy Metal Lathe
File:
ML100 parts #1.pdf
Various ML100 drawings
(1.24 MiB) Downloaded 1054 times
Andy B
Post by Andy B » Tue 22 Oct , 2019 20:50 pm
Another batch of ML part drawings (with a couple of 'US' numbers (whatever they are?)):
US100/305 Apron Eccentric Old Type 5in Viceroy Screwcutting Lathe
US100/305A&B Apron Driving Gear & Pinion (Old Type) 5in Viceroy Metal Lathes
ML100/202 Levelling Screw 5in Metal Turning Lathe
ML100/205 Cabinet Drain Plug 5in Viceroy Metal Lathe
ML100/208 Coolant Connecting Pipe 5in Viceroy Metal Lathes
ML100/208A Coolant Pipe 5in Viceroy Metal Lathe
ML100/210 Coolant Pump Motor Pulley 5in Viceroy Metal Lathe
ML100/211 Coolant Pump Pulley 5in Viceroy Metal Lathe
ML100/214 Coolant Connecting Block 5in Viceroy Metal Lathe
ML100/215 Reversing Switch Handle 5in Viceroy Metal Lathes
ML100/219 Coolant Drain Guard 5in Viceroy Metal Lathe
ML100/219 Coolant Drain Filter 280VS Bench Lathe
ML100/305A Apron Pinion (Dated 1968) 5in Metal Turning Lathe
ML100/305A Apron Pinion (Dated 1964) 5in Metal Turning Lathe
ML100/306 Handwheel Pinion (Dated 1963) 5in Viceroy Metal Lathe
ML100/306 Handwheel Pinion (Dated 1965) 5in Viceroy Metal Lathe
ML100/308 Apron Handwheel Handle 5in Viceroy Metal Lathes
ML100/310 Handle Support 5in Viceroy Metal Lathe
ML100/404 Bed Tenon 5in Viceroy Metal Lathes
ML100/406 Extended Fixing Screw For All Types. Gear Box
ML100/407 Extended Fixing Screw For All Types. Gear Box
Drawings file:
ML100-2-4 parts.pdf
ML100/2xx to ML100-4xx drawings
(2.09 MiB) Downloaded 1017 times
Andy B
Post by Andy B » Tue 22 Oct , 2019 20:54 pm
And another, ML100/5xx numbers this time:
ML100/505B 3 Ball Handle – Knob 5in Viceroy Metal Lathe
ML100/506 Locking Pad [with 1967 Mod] 5in Viceroy Metal Lathe
ML100/506 Locking Pad [1961 Original] 5in Viceroy Metal Lathe
ML100/510 Leadscrew Bush [1961 Original] 5in Viceroy Metal Lathe
ML100/510 Leadscrew Bush [1965 et seq. Mods] 5in Viceroy Metal Lathe
ML100/511 Feed Nut 5in Metal Turning Lathe
ML100/511A Top Slide Feed Nut (English) 5in Viceroy Metal Lathes
ML100/511A Top Slide Feed Nut (English) [1973 Mod] 5in Viceroy Metal Lathes
ML100/511B Top Slide Feed Nut (Metric) 5in Viceroy Metal Lathes
ML100/511B Top Slide Feed Nut (Metric) [1973 Mod] 5in Viceroy Metal Lathes
ML100/512 Feed Nut PCS Lathe Cross Slide Unit
ML100/512A Feed Nut (English) 5in Viceroy Metal Lathe
ML100/512B Feed Nut (Metric) 5in Viceroy Metal Lathe
ML100/512C Feed Nut (English) 5in Viceroy Metal Lathe
ML100/512D Feed Nut (Metric) 5in Viceroy Metal Lathe
ML100/513 Saddle Leadscrew Bush (English) 5in Viceroy PCS Lathe
ML100/513E Saddle Leadscrew Bush (English) 5in Viceroy Metal Lathe
ML100/513 Saddle Leadscrew Bush (English) [Mods] PCS Lathe Saddle Unit
ML100/513 Saddle Leadscrew Bush (English) [Original]5in Viceroy PCS Lathe
ML100/514 Cross Slide Leadscrew 5in Viceroy Metal Lathe
ML100/515 Top & Cross Slide Bearing Collar 5in Viceroy Metal Lathe
ML100/516 3 Ball Handle [1965] 5in Viceroy Metal Lathe
ML100/516 3 Ball Handle [1958] 5in Viceroy Educator
ML100/520 Top & Cross Slide Dial 5in Viceroy Metal Lathe
ML100/520A Top & Cross Slide Dial (ENG) [1978] Viceroy Metal Lathe
ML100/520A Top & Cross Slide Dial (ENG) [1965] 5in Viceroy Metal Lathe
ML100/520B Top & Cross Slide Dial (Metric) [1971] 5in Viceroy Metal Lathe
ML100/520B Top & Cross Slide Dial (Metric) [1978] Viceroy Metal Lathe
Drawings file:
ML100-5 parts.pdf
ML100/5xx parts
(5.31 MiB) Downloaded 1106 times
Pete.
Post by Pete. » Wed 23 Oct , 2019 0:19 am
Thanks Andy especially for that last one.
Pete.
Post by Pete. » Wed 23 Oct , 2019 0:30 am
Actually I've found what I think is an error in one of the drawings.
In ML100/512C FEED NUT ENGLISH the thread form is given as 1/2" x 10tpi modified square thread (LH). This is obviously the cross slide nut but in the drawing for the cross slide screw ML100/514 the thread form is given as 1/2" dia x 10tpi (LH) ACME FORM (as you'd expect). The metric nuts are usually modified square section but I think that the nut thread for the English nut here is mis-labeled and should actually be ACME, like it's mating screw, not modified square thread.
Sinbad
Hardware/Software: none
Post by Sinbad » Sat 02 Nov , 2019 14:25 pm
Hello, I have a 1984 Viceroy 280 Synchro with the 8 position imperial gearbox, does anybody have drawings for this lathe? I am trying to determine what size the stud gear should be.
Pete.
Post by Pete. » Sat 02 Nov , 2019 18:55 pm
I don't *know* the answer and I can't find a specific drawing but if you look at my post further up "Stud gears A-G for metric gearbox lathes" you'll see that the 24 tooth "D" letter gear is annotated differently to the rest of the set of 7. It doesn't specifically say 'metric' like the other 6 and includes the text 'special stud gear for reversing bracket' which the others don't include.
Added to that Page 13 of the replacement parts list shows the stud gears as 42 and 24 teeth. 42T must be the gear that meshes with the pair of 32 tooth reversing idlers and the 24T is the first driver for the end train I guess. The drawing number in the parts list also matches the stud gear 'd' drawing number ML115/948.
Pretty sure it's that one - 24Teeth, 16DP, 20PA
rpwilson
Post by rpwilson » Sat 02 Nov , 2019 19:06 pm
As far as I can tell, if its an imperial lathe with the 8 position gearbox, and you are using it to cut imperial threads, that stud gear should be 24T, drg No. ML.115/948.
Richard
Sinbad
Post by Sinbad » Thu 07 Nov , 2019 18:37 pm
Thanks for the replies, I suspected the stud gear should be 24 teeth but reassuring to have confirmation. Now I have to find one!
Andy B
Post by Andy B » Mon 20 Jul , 2020 15:03 pm
ML124 Splash Guards
ML124.PDF
(143.85 KiB) Downloaded 1039 times
ML124A.PDF
(89.59 KiB) Downloaded 1034 times
ML124B.PDF
(102.85 KiB) Downloaded 1042 times
Please don't add comments in this thread - it makes it harder for people to find stuff.
