TDS GB/M Gearbox problem
Ibbo
Hardware/Software: Viceroy metric TDS1/16 BL
Post by Ibbo » Wed 17 Aug , 2011 0:00 am
Can anybody advise
I have a broken shaft Drawing ML 115/900/M Section E-E
The shaft has gone at the circlip on ML-115 930
can it be replaced?
Re: TDS GB/M Gearbox problem
Post by bradders » Wed 17 Aug , 2011 6:52 am
Denfords have no spares for these machines
Ibbo
Post by Ibbo » Wed 17 Aug , 2011 14:47 pm
Looks like iI will have to try and make one
at least I have a lathe
Andy B
Post by Andy B » Wed 17 Aug , 2011 16:02 pm
Steve,
Sorry to hear about your broken shaft.
Have you found the detail drawing amongst those already scanned and posted on here?
If you can't find it, let me know and I'll have a look through the originals.
Ibbo
Post by Ibbo » Wed 17 Aug , 2011 18:16 pm
Hi Andy
I,ve got drawing ML 115/900/M Section E-E
If there is a more detailed one I'd love a copy
Thanks a lot
Andy B
Post by Andy B » Thu 18 Aug , 2011 15:40 pm
Steve,
Are you sure that is the number for the shaft?
ML 115/930 can be found in this pdf - https://www.denfordata.com/downloads/for ... 0scans.pdf - which shows a fixed dog & gear.
Can you post up the relevant part of the assembly drawing that you have?
Edit - just found the assembly drawing ML 115/900/M on a different thread, and I think the shaft number is ML 115/923.
I'll see if I have it - may take a couple of days.
Second edit - found the drawing - will try to get it scanned tomorrow.
Andy B
Post by Andy B » Fri 19 Aug , 2011 11:00 am
Drawing ML115/923 has had 10 modifications over the years.
Attched are the mod notes as far back as still exist - I don't know what happened to them for pre-1967
Steve - you don't say what year your lathe is, so i hope these cover far enough back to match the design of your broken shaft.
Mod note 1541-68.pdf
(40.78 KiB) Downloaded 878 times
Mod notes 1652 & 1685-69.pdf
(79.39 KiB) Downloaded 700 times
Mod note 1741-70.pdf
(55.83 KiB) Downloaded 845 times
Mod note 1999-72.pdf
(95.78 KiB) Downloaded 741 times
Mod note 2798-79.pdf
(61.44 KiB) Downloaded 645 times
Andy B
Post by Andy B » Fri 19 Aug , 2011 12:32 pm
And here is the drawing.
ML115-923.pdf
(1.35 MiB) Downloaded 793 times
Ibbo
Post by Ibbo » Sat 20 Aug , 2011 0:50 am
Thanks a lot Andy I'm sure they will be a great help
I will look through them later today
I'm not sure of the lathes age I will try to find the serial number when I've had a bit of sleep
cheers
Ibbo
Post by Ibbo » Tue 23 Aug , 2011 15:08 pm
Hi Andy
Thats the shaft
thanks a lot
Now I've just got to get the confidence to start making it
