VersaLASER foam board cutting settings
Posted: Mon 25 Sep , 2006 16:03 pm
by woody
We have versaLASER V300 and want to cut 6mm foam board.
Please can you advise on suitable settings to cut without burning the core.
Posted: Mon 25 Sep , 2006 17:37 pm
by Steve
I have not tried to cut foam board before but would suggest you try either selecting a very soft material and see how it cuts. If it does not cut through try increasing the intensity or a different material setting.
You could also try two passes over the same part or deep engraving (on a blue line) for somthing like Perspex.
To get the right settings for any material is all a bit trial and error. Just draw a small simple shape and see what happens. Start with the lowest settings and work up.
Posted: Sun 24 Jun , 2007 11:39 am
by bob-in-dav
This response is probably much too late but others may be interested too.
I have managed to cut 6mm foamboard on the Versalaser with the material setting on "Balsa Wood"
However - the foam core shrinks back significantly with the heat giving an inward radius to the finished cut.
Give it a try - it might be OK for your application.
