shadow image
Posted: Tue 14 May , 2013 13:08 pm
by d jones
When rastoring and rastoring a photo im getting a double image only slightley but it makes a poor image ,looks blured.,how can this be inproved? thank you .
Re: shadow image
Posted: Tue 14 May , 2013 14:00 pm
I'm no expert on Lasers but have you cleaned the mirrors and double checked the height setting is correct ?
https://denfordata.com/bb/viewtopic.php?f=5&t=1322
Remember the laser beam has a focus point where it's at it's smallest and most powerful, then the beam widens which is why you get slightly tapered edges when cutting through a thicker sheet.
Re: shadow image
Posted: Tue 14 May , 2013 14:10 pm
by d jones
the depth z appears ok ,it when its in rastor the text and image has a off set image to the left.only by 0.19 mm (gessing)
Re: shadow image
Posted: Tue 14 May , 2013 14:13 pm
by bradders
Make sure the X axis stepper motor timing belt pulley, is securely fastened to the stepper motor shaft. via the imperial Allen screw on the pulley, if its slack you get backlash which can cause the double image.
Re: shadow image
Posted: Tue 14 May , 2013 14:18 pm
It could be backlash in one of the axes...is the shadow visible in one axis, ie left/right or up/down ?
Re: shadow image
Posted: Tue 14 May , 2013 14:46 pm
What is the tuning value set to?
When you raster it fires from both directions so thefore it draws 2 seperate vertical lines. When you adjust the tuning it drops both lines on the same point. The normal value would be between +6 & +8.
Re: shadow image
Posted: Tue 14 May , 2013 14:52 pm
by bradders
wear and debris on the belts can have an effect too.
Re: shadow image
Posted: Fri 31 May , 2013 13:38 pm
by d jones
Martin wrote:What is the tuning value set to?
yep the value was way too high , +7 did the trick . spot on.
thanks
