Techsoft Ver2 not the correct drawing size for the Laser bed
Posted: Tue 29 Jun , 2010 11:59 am
When I run Techsoft Ver 2 the drawing size does not match the Versa Laser (VL 200 in this case bed size), it is only 297 x 297 when i go into the following.......
SETUP > DRAWING > LAYOUT > Match to current printer (Which your laser should be set as your default printer)
