VL300 Connection to PC & Firmware
Posted: Tue 02 Oct , 2007 12:24 pm
by Crakkers
Installed versa laser on standalone PC. everytime I switch PC on it states new hardware found and looks for firmware. Laser extraction is constantly switched on - noisy! but can not control machine via PC.
Please advise exactly what software I need to download. Original disks are lost!!!
Op system is XP
Posted: Tue 02 Oct , 2007 14:49 pm
by bradders
Posted: Tue 02 Oct , 2007 20:58 pm
by Crakkers
does not answer the question.
why does new hardware found come on everytime I boot PC up, even though software has been installed and reinstalled many times, as per your instructions?
Posted: Wed 03 Oct , 2007 19:52 pm
It sounds like you have a problem on one of the USB devices.
Try looking at the USB devices in device manager & check that they are all installed correctly. If one shows a error then try to update the device.
Posted: Thu 04 Oct , 2007 9:01 am
by Steve
It is probably somthing to do with access rights on the computer.
Have you tried logging on as an administrator then loading the laser drivers. It may be as a standard user the changes you are making each time are not being saved.
Posted: Thu 04 Oct , 2007 10:50 am
by ULS Service
it looks like the usb board from your pc, does search it every time, because otheriwse there will be no reason, why it alswys shows you that a new device was found.
Maybe try to connectg the machine to another usb board on your pc or try to upgrade your usb board drivers.
regards
Bernhard
