Versa Laser VL300 / VL200 drivers for Vista. I thought we had got the problem licked, however, if I install the drivers with the laser connected it works fine but as soon as the laptop is switched off and rebooted I get the error message that "The port monitor has not been properly installed - you may need to uninstall the Versalaser software then reinstall it".
This then, prevents the laser from being recognised by the laptop and nothing works.There is obviously still a problem so any advice you may be able to give me would be very welcome.
VL300 / VL200 Vista driver "Port Monitor" error
- bradders
VISTA Drivers
Just to keep you updated:
VLS/PLS Vista Drivers should working without any problems. Just note: 64 BIT VISTA will be not supported at the moment.
VL VISTA Drivers are still under development.
regards
Bernhard
regards
Bernhard
best regards
Bernhard
Bernhard
