Turn 270 Pro door stuck
All info relating to the Denford Turn270 and NewTurn270 CNC lathes
dixonsca
Hardware/Software: Denford Magnum router. (now upgraded to a 3d router using retrofit kit macmotion controller and upgraded stepper motors)
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
Makerbot Replicator 2
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d
Post by dixonsca » Tue 27 Nov , 2012 14:21 pm
After a morning of turning parts, I returned in the afternoon to continue but our beloved Turn270 Pro fancied the afternoon off and wouldnt let me open the door!
I have powered the lathe off and rebooted the pc but to no avail, the door simply wont open. I have removed the 2 nuts from the locking mechanism to get round the problem temporarily however doing this means the lathe now has no saftey feature.
Any ideas why the door will not release are welcomed?
Re: Turn 270 Pro door stuck
Post by Denford Admin » Tue 27 Nov , 2012 14:48 pm
I'd guess it's a fuse blown.
dixonsca
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d
Post by dixonsca » Tue 27 Nov , 2012 19:47 pm
the fuses are all ok and the guard release relay engages when the lathe is powered on. :(
Post by Denford Admin » Wed 28 Nov , 2012 10:31 am
It's either the guard release solenoid has failed, or the wiring from the PCB to the solenoid is faulty.
I've just opened up a new guard switch and put an ohm meter across E1 and E2 the solenoid inputs...it read 2000ohms. It'd be worth checking that (with the wires removed)
Check the voltage is going to those same pins when the guard release relay is energised (it should be 24V DC)
