ATC leaking air help
andy_con
Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
Post by andy_con » Fri 09 Apr , 2021 10:08 am
the up/down air piston is badly leaking air, what are my options?
can you buy these new?
jamesgates1000
Hardware/Software: 2001 Cyclone with toolchanger and Fanuc 21i control
Serial number - H00913.
Voltage 415V F.L.C 20A 50Hz 3Ph
1997 Triac VMCwith toolchanger and Fanuc O-M control
Serial number - 70826B.
Voltage 415V F.L.C 30A 50Hz 3Ph
Re: ATC leaking air help
Post by jamesgates1000 » Sun 11 Apr , 2021 20:40 pm
Hi Andy,
I hade a similar issue when I had my Triac but on the in/out cylinder.
viewtopic.php?f=47&t=4994&p=19621#p19621
I ended up getting a replacement from Harrier Pneumatics in Bristol for £64
moray
Hardware/Software: Triac VMC
Post by moray » Sun 11 Apr , 2021 22:51 pm
I had to replace both on my Triac when I bought it.
I bought them from https://www.airlines-pneumatics.co.uk/p ... a/s030100/
although I see prices have gone up quite a bit since I bought them.
I think the up/down ram is part number 105608, and the in/out is 105610. There should be a sticker on the cylinder with the details.
