Fanuc Triac - ATC Problem
Posted: Mon 19 Oct , 2015 8:24 am
by jamesgates1000
Hi, having an issue with my Triac's ATC.
I can rotate the carousel with the buttons on the control and the draw bar works using the manual button.
However if I try to do a toolchange using an M6 the tool changer doesnt retract.
Also if I try to change when these is a tool in the spindle the atc doesnt move all the way in to pick up the tool, as if there is not enough pressure to overcome the springs that hold the tool.
https://youtu.be/Z_c7Jwq4AGg
I have a constant light stream of air coming from the under the back of the cabinet, feels like a push connector down there, should there be a brass filter here? thinking maybe it has got damaged when it was put on a pallet.
Re: Fanuc Triac - ATC Problem
Posted: Mon 19 Oct , 2015 8:54 am
Does the arm in/out work correctly if you program it manually?( M20 Arm in, M21 Arm out.)
You maybe able to adjust the valves on the cylinder but make sure the air pressure is up at over 80psi.
Posted: Wed 21 Oct , 2015 10:12 am
by jamesgates1000
I tested this last night. The M20 works fine, even when there is a tool in the spindle, but the M21 doesn't make the carousel retract., although it can be pushed back by hand.
https://youtu.be/5w_I0Fdyeps
Seems like more air comes out of the exhaust under the cabinet when i input the M21
The air pressure to the machine is at a constant 100psi.
Any idea what could be stopping the cylinder retracting
Posted: Wed 21 Oct , 2015 12:31 pm
Can you try inverting the pipes to the cylinder?
Posted: Thu 22 Oct , 2015 10:07 am
by jamesgates1000
I inverted the pipes to the cylinder last night, the carosel moved forward to the spindle, but when i inputted a M20 to retract it, i still failed to retract.
Put the pipes back on as they should be, then watched the soleniods. When i used the M20 an LED on the centre solenoid lit up but when I used a M21 it didn't.
Don't know if this helps, the machine looks like it has been in storage for a while, so i guess some oil could have gummed up the valve.
Am I right in thinking that test indicates a problem with the cylinder?
I guess I should check the seals on the cylinder to see if any air is escaping.
Posted: Tue 17 Nov , 2015 13:10 pm
by jamesgates1000
Took the pipes off the top of the cylinder one by one and found that an internal seal had gone.
Went to my local pneumatic supplier in Bristol(Harrier Pneumatics) and got a Parker PIA-5025MS-0150 as a direct replacement for £64.
ATC is working fine now.
Posted: Wed 14 Apr , 2021 15:36 pm
by andy_con
here are some photos of mine, is the parker one a direct replacement for mine?
looks like something has been cut off the top of mine
is this the correct one from Rs?
https://uk.rs-online.com/web/p/pneumati ... lsrc=aw.ds
Posted: Fri 16 Apr , 2021 17:05 pm
I don't think it is correct.
I always thought the stoke lengths are 100mm for up/down & 150mm for in/out.
Posted: Mon 19 Apr , 2021 9:03 am
by andy_con
Can anyone offer any help, am struggling to find one
Posted: Tue 20 Apr , 2021 12:48 pm
Posted: Wed 21 Apr , 2021 9:47 am
by andy_con
many thanks, i best just double check the screw connectors are the same.
