RS232 communicator does not connect
Triac PC. Installed V5 Milling and security key accepted. Should I be installing another driver or more software to enable communication ?
Re: RS232 communicator does not connect
You may have the wrong machine selected in v5, there are no special drivers required for RS232 (as long as the COM port is enabled and active in windows)
See this post and look at the .pdf files in the first post.
viewtopic.php?f=2&t=2903
