Cassette tapes
Posted: Tue 06 Jul , 2010 9:20 am
by Robin Rhodes
Hi, I have just acquired a 1985 TRIAC which seems to be working OK but has no tapes. Can anyone help with sourcing them? Robin Rhodes
Re: Cassette tapes
Posted: Tue 13 Jul , 2010 16:19 pm
by alanhende
Hi Robyn,
Did you get the tape I sent you & did it work?
I can repair the cassette unit if its not working or I could supply a refurbished service exchange unit.
Alan
Re: Cassette tapes
Posted: Tue 13 Jul , 2010 17:02 pm
by Robin Rhodes
Hi Alan
Thanks for the tape: still no success.
The cassette seems to be working to some extent but I don't think correctly. When trying to record the tape moves intermittently at about 1/2 second intervals. The tape is not in the best of condition but I tried on parts that seemed better with no difference.
I have also been trying to get the RS232 link working using the Denford Industrial Text Editor. Again no success. Some data seems to pass but then stops.
So all in all I am not sure what to do. The long term plan was to switch to Mach3 but I have some work I need to do first.
The plug in replacement for the cassette is interesting but I doubt if there is much of a market for it as most people seem to be going Mac3. Is it possible to use USB Memory Stick memory? I assume that would open up the data transfer possibilities.
So I am sat here scratching my head.
Robin
Re: Cassette tapes
Posted: Thu 15 Jul , 2010 12:48 pm
by alanhende
Hi Robyn,
I can repair the cassette unit. The USB idea is a non starter.
Im not familiar with the Denford text editor. I use 'Coolterm' which is free on the web. From what I can remember when I used to test these things, the controller must see an <STX> then the command/program then<ETX>
So for example you were typing a single move block you would type Ctrl+B then G01X100 then Ctrl+C.
Also, have you checked the test mode to make sure the serial port is working?
Alan
