denford triac 1987 atc with toolchanging & air problems
Posted: Wed 10 Mar , 2010 21:51 pm
i have a denford triac 1987 and the atc has been playing up i had to replace all of the airlines on the machine as they were ether split or leeking but the machine still leaks my problem is i can use a whole tank of air in one tool change as soon as i turn the ari above 20 psi somethin clicks on and air pours out! thing it i can't find from where? i think it maby the valves which open & close are worn do i need to change seals? or do i need to buy new valves if so where do i get the parts?
my second problem is the draw bar it will not always open fully and sometimes jams...with holders half way up the tool caracell pushes them up and it jams colses the drawbar and drops the tools, looks like the whold atc is not moving enought towards the spindle....can i adjust this and which do i move the swiches or the piston nuts? also it has a habit of not alinging the spindle in a toolchange... error code spindle drive fault when the spindle wont stop in the right place ,this only happens 1-10 toolchanges i dont know if the two are connected problems?
any help i would apreciate!!
