Fanuc OM controller - Z axis problems
David Yori
Post by David Yori » Sun 26 Jul , 2009 9:42 am
Help ! My Triac ATC with Fanuc OM controller was working fine, but I was playing around trying to get the DNC input working. Now the z axis wont move, and is stuck in the home position. When you try and jog, the x & y axis move, OK with the leds on the relevant switches lighting, but the leds for the z axis dont light, and the axis will not move. Any idea what i could have done ? Thanks.
Re: z axis probles
Post by Denford Admin » Mon 27 Jul , 2009 8:37 am
Have you been changing parameters to get the DNC working ? Maybe you've altered the wrong one ?
David Yori
Re: Fanuc OM controller - Z axis problems
Post by David Yori » Mon 27 Jul , 2009 9:13 am
Yep, spot on. I managed to change one of the parameters as advised somewhere or other. Everything is now working, and even have the DNC drip feed working perfectly. Cant beleive it. Still a few niggly issues, but i'm getting there. When I turn the machine on, the units alway go back to inches. How can i make it stay in mm ? Is there anywhere where I can download all of the parameters/diagnostics for this machine for future debugging ? Thanks.
Post by Denford Admin » Mon 27 Jul , 2009 9:50 am
I think you'd be best downloading your current parameters and printing them out.
There are some manuals on here and I thought I'd seen parameters listings, but the chances of them being correct for your particular machine are slim.
viewtopic.php?f=15&t=1813&hilit=triac+fanuc
viewtopic.php?f=15&t=1921&hilit=triac+fanuc
Triac whizz wrote:Did you know you can back up the 900 parameters?
Press EOB and output start at the same time: viewtopic.php?t=391&highlight=900+parameters
David Yori
Post by David Yori » Mon 27 Jul , 2009 11:16 am
OK, thanks. Will try the backup.
