During a test run I found that G81/82 etc have a possible bug in them, they totally ignore any value in the Z work offset.
I had put +25mm in the Z work offset to make sure my tools were clear of the job and the canned cycles drilled to the original zero position, everything else was 25mm above.
I removed the Z offset and ran the program without a hitch.
I am running a Triac PC servo using version 1.30 Denford software, is there a later version?
Is this a known fault or is it me doing something stupid.
Graham
Work offset question
