Denford Triac Miller - Keyboard gives wrong values
Hi, I have a Denford Triac Miller and the key board has gone wrong when i press x i get y and when i press 9 i get 6 can any one help
Re: Denford Triac Miller - Keyboard gives wrong values
Can you supply more information please.
Control type?
Software version?
Keypad?
Control type?
Software version?
Keypad?
sorry dont know whot the software is can send you some photos if that helps the mother board is made by north east eletronics but dont seem to be able to get in touch with them i only imput the program though the key pad can this machine be convertd to run from a laptop and any though to the cost
Triac PNC3 then.
Have you tried running the keyboard test? -
Hold a button in & power up the control. You can then
press any button to display it's relevant number. I am
not sure what order the buttons go in but it should help to check & work out where
the fault is.
the fault is.
thanks but whitch button do i hold in ? to test key pad and after do i press all the key pad numbers
have tryed the key board test and it seems ok tried the miller today and it did its job fine so dont know whot is wrong till next time it plays up
