I have just purchaesd a Triac with an atc the Fanuc jog wheel is stiff,
is this normal, or can It be stripped to inprove its movement.
also how big a 240 - 415 power converter do I need to run this machine with a 1.5 hp motor.
Triac Fanuc jog wheel and three phase power converter
- Lone_Ranger
Re: Triac Fanuc jog wheel and three phase power converter
Fanuc Pulse Generator wheel is usually very free and moves in very small "clicks" ie positions so it sounds like it is "gunged up" and needs a good clean out or there is a mechanical fault, either way it will need to be stripped. ( Carefully!! )Tony Pike wrote:I have just purchaesd a Triac with an atc the Fanuc jog wheel is stiff,
If you want to run a 3 phase machine from a single phase outlet the "rule of thumb" is usually 2 1/2 times the spindle HP plus minimum 2 times the sum of the 3 servo motors HP, then add a bit for all the fans that run in the cabinet and things like coolant pump etc then you should be looking at a minimum 5 Hp unit, probably 7+ Hp to be comfortable.
