Member's favourite coolants
Count Triacula
Hardware/Software: Triac
6 Station ATC
Mach 3
Post by Count Triacula » Fri 15 Jan , 2016 22:59 pm
I'm new to the site and new to cnc in general. I have a Triac with an auto flood coolant system and I am mostly machining aluminium at the moment.
I was wondering what suitable coolants other members were using as I am having trouble finding Cincinnati Millacron Simcool C60, the coolant reccommended in the Triac manual, from a UK suppier. Ideally I'm looking for something which isn't too hard on the lungs once the particles become airborne.
Any help advice would be greatly appreciated.
Count Triacula
jamesgates1000
Serial number - H00913.
Serial number - 70826B.
Re: Member's favourite coolants
Post by jamesgates1000 » Mon 01 Feb , 2016 12:14 pm
I use Fuchs ecocool ultralife A, I find that even if I leave my machine for a week I don't get any bacterial growth. Not too expensive either, you can buy it from Cromwell tools.
Count Triacula
6 Station ATC
Mach 3
Post by Count Triacula » Mon 01 Feb , 2016 13:51 pm
Many thanks for taking the time to reply James. I went for Multispec multicut soluble oil from Chronos in the end. So far so good. I will definitely look into your recommendation next time.
Thanks again
dubstar_04
Hardware/Software: Triac PC (1998, easychange), Mach4, Fusion 360.
NovaTurn NS, VR Turning, Fusion 360
Post by dubstar_04 » Sun 02 Oct , 2016 9:09 am
jamesgates1000 wrote:Hi,
I've been using this too. I really like it so far. Doesn't smell at all.
