denford triac fanuc atc om-c parameter lost and alarm 510 ..
masroorkhan
Post by masroorkhan » Mon 23 Mar , 2015 13:36 pm
kindly help me i am new and not know much about different parameter and there function.
i replace old battery and lost all my parameter i manually enter the parameter 1 to 8393 (see the attached file) except the one with p_ _ _ _ _ _ _ _ because i didn't know what to enter.but still getting the following error.
alarm description
510 over travel +x
521 over travel -y
531 over travel -z
401 servo verdy off
420 servo y axis excess error
i also read the corresponding alarm in om c maintenance manual and the remedy they suggested didn't help me because i didn't know what parameter they are referring to and what value should i give to that parameter for denford triac fanuc atc vmc. the machine was perfect before i replace the backup battery. kindly help me
fanuc parameters from manual.pdf
(2.81 MiB) Downloaded 1597 times
Re: denford triac fanuc atc om-c parameter lost and alarm 51
Post by Martin » Mon 23 Mar , 2015 15:38 pm
You will need to set the machine limit values for parameters 700 to 707.
They should be roughly,
700 P 00250000
701 P 00015000
702 P 00015000
703 P 99999999
704 P-00040000
705 P-00160000
706 P-00185000
707 P-09999999
You will also need to set the 450 diagnostics. Make sure you set 450.0 to 1 (It will change back to 0 but sets timers)
viewtopic.php?f=47&t=981&hilit=450
masroorkhan
Post by masroorkhan » Mon 23 Mar , 2015 16:36 pm
thanks i will enter these value tomorrow.
but before that i am bit confuse regarding the stoke limit parameter 700 to 707.
it says for 700 (Stroke limit 1 located right to ref. point X axis).
can you explain whats mean by reference point x axis because after clear the machine memory how the machine know what's my reference point is.
Post by Martin » Mon 23 Mar , 2015 23:45 pm
When you power up the machine you need to send the machine to it's home position on both axis. This is then refered to as the reference point. Then parameter 700 is the X + Software Limit which is set roughly 5mm before the hardware limit switch.
700 X +
701 Y +
702 Z +
703 IV +
704 X -
705 Y -
706 Z -
707 IV -
masroorkhan
Post by masroorkhan » Tue 24 Mar , 2015 10:19 am
sir the 510 and 521 alarm are clear after i enter the parameter 700 to 707.
but the following alarm are still there
531 over travel -z
401 servo alarm y axis vrdx off
420 servo alarm y axis excess error
another thing you mention is diagnostics setting.when i enter the 450 diagnostic 00000001 it didn't take value so i check another diagnostic 400 or 410 and try to give some value but these diagnostic also not taking value.
another thing i want to clear regarding servo setting and servo motor tuning is there any connection with 401 and 420 alarms.
you mention that when you start the machine you have to send the machine to home position but how can i send the machine to home position because there the two alarm still there when i start the machine with (can and p) press 401 and 420 alarm my home and jog key are not working.
Post by Martin » Tue 24 Mar , 2015 12:22 pm
You need to clear all the alarms first which may just be the 450 diagnostics.
It does sound like you need to set the 450 diagnostics. Make sure you have PWE set to 1 & are in edit mode.
Have you got the machine serial number?
masroorkhan
Post by masroorkhan » Tue 24 Mar , 2015 13:51 pm
machine serial no is E04788B TRIAC FANUC 1996
software version plc 3.70l
we haven't diagnostic setting for that from denford we have parameter list but don't have diagnostic list can you guid us how to give diagnostic setting. 900 parameter list is also missing in denford manuals.the company didn't provide that so we didn't enter the 900 parameter.
kindly provide the diagnostic setting and 900 parameter for the given machine.
i change pwe bit to 1 but can't edit the diagnostic setting
Post by Martin » Tue 24 Mar , 2015 15:53 pm
Attached is the electrical record sheet for your machine with the relevant parameters/diagnostics.
EO4788B.DOC
(26.5 KiB) Downloaded 821 times
masroorkhan
Post by masroorkhan » Tue 24 Mar , 2015 16:31 pm
thank you sir i am impressed how you find that because it's 19 year old record i think.
i will enter these parameter tomorrow and inform you.
thanks again for your cooperation
Post by Martin » Tue 24 Mar , 2015 17:22 pm
Good luck.
Makes it a lot easier with a serial number.
masroorkhan
Post by masroorkhan » Wed 25 Mar , 2015 11:08 am
sir after entering the parameter and diagnostic from above attached file now the operator panel is now working but still there is some alarm
alarm
521 z axis over travel which i will clear with (can and p) press but the other two alarm are still there
401 and 420
the bazaar effect is that when i restart the machine only these two alarm appear 401 and 420 but when press the rest button
the alarm change to 401 and 410.
alarm 410 and 420 are changing with rest button some time both appear some time one or another appear.
this thing give me some hint that the driver board is ok but some parameter is incorrect either servo initial setting or servo tuning setting.
and i thing the 401 is because of 420 or 410.
kindly help me how to remove the 401 and (410 or some time 420 bazaar effect)
Post by Martin » Wed 25 Mar , 2015 12:10 pm
It may be worth staring from scratch.
Press the Del & Can butoons & hold in while powering up.
Input the 900 Parameters
Input the all Parameters except 900
Input 450 Diagnostics & set 453 bit 0 to 1 (Will change back to 0)
masroorkhan
Post by masroorkhan » Wed 25 Mar , 2015 15:00 pm
sir i did what you said reset the memory and then enter the value in above given sequence.
the only alarm clear from this process is 531
the other two alarm is still there 401 and 420
i did an experiment with parameter value 593 to 596 which is set to 100. i change that parameter value 430 the controller circuit board produce some transformer noise for 5 to 6 seconds and then show alarm 424 and 414 and the other alarm 401 and 410 been clear but when i change parameter no 593 to 596 to value 100 again. the alarm 424 and 414 disappear and 401 and 410 appear with no transformer noise only a relay opening and closing sound.
Post by Martin » Wed 25 Mar , 2015 15:35 pm
Can you check them against the list below.
(New settings for 2-0sp motors,10,000 pulse encoders.12/05/93)
N0001 P 00000000
N0002 P 00000001
N0003 P 00000001
N0004 P 00010000
N0005 P 00010000
N0006 P 00010000
N0007 P 00010000
N0008 P 00000011
N0009 P 01000100
N0010 P 10000000
N0011 P 01000000
N0012 P 00000001
N0013 P 00000001
N0014 P 00000000
N0015 P 10000000
N0016 P 00000000
N0017 P 00000000
N0018 P 00000000
N0019 P 00000000
N0020 P 00000000
N0021 P 00000000
N0022 P 00000000
N0023 P 00000000
N0024 P 00000000
N0025 P 00000000
N0026 P 00000000
N0027 P 00000000
N0028 P 00000000
N0029 P 00000000
N0030 P 00000000
N0031 P 00000000
N0032 P 00000000
N0033 P 00000000
N0034 P 00000000
N0035 P 10000000
N0036 P 00000000
N0037 P 10000000
N0038 P 10100100
N0039 P 00000000
N0040 P 00010000
N0041 P 00000000
N0042 P 00000000
N0043 P 00000000
N0044 P 00000000
N0045 P 00000000
N0046 P 00000000
N0047 P 00000000
N0048 P 10000000
N0049 P 00000000
N0050 P 00000000
N0051 P 00000000
N0052 P 00000000
N0053 P 00000000
N0054 P 00000000
N0055 P 00000000
N0056 P 00000000
N0057 P 00000000
N0058 P 00000000
N0059 P 00000000
N0060 P 00000100
N0061 P 00000000
N0062 P 00000000
N0063 P 00000000
N0064 P 00000000
N0065 P 00000000
N0066 P 00000000
N0067 P 00000000
N0068 P 00000000
N0069 P 00000000
N0070 P 00000000
N0071 P 00000000
N0072 P 00000000
N0073 P 00000000
N0074 P 00000000
N0075 P 00000000
N0076 P 00000000
N0077 P 00000000
N0078 P 00000000
N0079 P 00000000
N0080 P 00000000
N0100 P 00000008
N0101 P 00000008
N0102 P 00000008
N0103 P 00000002
N0104 P 00000000
N0105 P 00000000
N0106 P 00000000
N0107 P 00000000
N0108 P 00000001
N0109 P 00000000
N0110 P 00000100
N0111 P 00000000
N0112 P 00000000
N0113 P 00000000
N0114 P 00000000
N0115 P 00000000
N0116 P 00000000
N0117 P 00000000
N0118 P 00000000
N0119 P 00000000
N0120 P 00000000
N0121 P 00000100
N0122 P 00000000
N0123 P 00000000
N0124 P 00000000
N0125 P 00000000
N0126 P 00000000
N0127 P 00000000
N0128 P 00000000
N0129 P 00000000
N0130 P 00000005
N0131 P 00000006
N0132 P 00000001
N0133 P 00000002
N0134 P 00000004
N0135 P 00000003
N0136 P 00000000
N0137 P 00000000
N0138 P 00000000
N0139 P 00000000
N0140 P 00000079
N0141 P 00000080
N0142 P 00000084
N0143 P 00000032
N0144 P 00000083
N0145 P 00000084
N0146 P 00000079
N0147 P 00000080
N0148 P 00000084
N0149 P 00000069
N0150 P 00000065
N0151 P 00000067
N0152 P 00000072
N0153 P 00000000
N0154 P 00000000
N0155 P 00000000
N0156 P 00000090
N0157 P 00000032
N0158 P 00000076
N0159 P 00000079
N0160 P 00000067
N0161 P 00000075
N0162 P 00000000
N0163 P 00000000
N0164 P 00000068
N0165 P 00000078
N0166 P 00000067
N0167 P 00000000
N0168 P 00000000
N0169 P 00000000
N0170 P 00000000
N0171 P 00000000
N0172 P 00000000
N0173 P 00000000
N0174 P 00000000
N0175 P 00000000
N0176 P 00000000
N0177 P 00000000
N0178 P 00000000
N0179 P 00000000
N0180 P 00000000
N0181 P 00000000
N0182 P 00000000
N0183 P 00000000
N0184 P 00000000
N0185 P 00000000
N0186 P 00000000
N0187 P 00000000
N0188 P 00000000
N0189 P 00000000
N0190 P 00000000
N0191 P 00000000
N0192 P 00000000
N0193 P 00000000
N0194 P 00000000
N0195 P 00000000
N0196 P 00000000
N0197 P 00000000
N0198 P 00000000
N0199 P 00000000
N0200 P 00000000
N0201 P 00000000
N0202 P 00000000
N0203 P 00000000
N0204 P 00000000
N0205 P 00000000
N0206 P 00000000
N0207 P 00000000
N0208 P 00000000
N0209 P 00000000
N0210 P 00000000
N0211 P 00000000
N0212 P 00000000
N0213 P 00000000
N0214 P 00000000
N0215 P 00000000
N0216 P 00000000
N0217 P 00000000
N0218 P 00000000
N0219 P 00000000
N0220 P 00000000
N0221 P 00000000
N0222 P 00000000
N0223 P 00000000
N0224 P 00000000
N0225 P 00000000
N0226 P 00000000
N0227 P 00000000
N0228 P 00000000
N0229 P 00000000
N0230 P 00000000
N0231 P 00000000
N0232 P 00000000
N0233 P 00000000
N0234 P 00000000
N0235 P 00000000
N0236 P 00000000
N0237 P 00000000
N0238 P 00000000
N0239 P 00000000
N0240 P 00000000
N0241 P 00000000
N0242 P 00000000
N0243 P 00000000
N0244 P 00000000
N0245 P 00000000
N0246 P 00000000
N0247 P 00000000
N0248 P 00000000
N0249 P 00000000
N0250 P 00000000
N0251 P 00000000
N0252 P 00000000
N0253 P 00000000
N0254 P 00000000
N0255 P 00000000
N0256 P 00000000
N0257 P 00000000
N0258 P 00000000
N0259 P 00000000
N0260 P 00000000
N0261 P 00000000
N0262 P 00000000
N0263 P 00000000
N0264 P 00000000
N0265 P 00000000
N0266 P 00000000
N0267 P 00000000
N0268 P 00000000
N0269 P 00000000
N0270 P 00000000
N0271 P 00000000
N0272 P 00000000
N0273 P 00000000
N0274 P 00000000
N0275 P 00000000
N0276 P 00000000
N0277 P 00000000
N0278 P 00000000
N0279 P 00000000
N0280 P 00000000
N0281 P 00000000
N0282 P 00000000
N0283 P 00000000
N0284 P 00000000
N0285 P 00000000
N0286 P 00000000
N0287 P 00000000
N0288 P 00000000
N0289 P 00000000
N0290 P 00000000
N0291 P 00000000
N0292 P 00000000
N0293 P 00000000
N0294 P 00000000
N0295 P 00000000
N0296 P 00000000
N0297 P 00000000
N0298 P 00000000
N0299 P 00000000
N0300 P 00000000
N0301 P 00000000
N0302 P 00000000
N0303 P 00000000
N0304 P 00000000
N0305 P 00000000
N0306 P 00000000
N0307 P 00000000
N0308 P 00000000
N0309 P 00000000
N0310 P 00000000
N0311 P 00000000
N0312 P 00000000
N0313 P 00000000
N0314 P 00000000
N0315 P 00000000
N0316 P 00000000
N0317 P 00000000
N0318 P 00000000
N0319 P 00000000
N0320 P 00000000
N0321 P 00000000
N0322 P 00000000
N0323 P 00000000
N0324 P 00000000
N0325 P 00000000
N0326 P 00000000
N0327 P 00000000
N0328 P 00000000
N0329 P 00000000
N0330 P 00000000
N0331 P 00000000
N0332 P 00000000
N0333 P 00000000
N0334 P 00000000
N0335 P 00000000
N0336 P 00000000
N0337 P 00000000
N0338 P 00000000
N0339 P 00000000
N0340 P 00000000
N0341 P 00000000
N0342 P 00000000
N0343 P 00000000
N0344 P 00000000
N0345 P 00000000
N0346 P 00000000
N0347 P 00000000
N0348 P 00000000
N0349 P 00000000
N0350 P 00000000
N0351 P 00000000
N0352 P 00000000
N0353 P 00000000
N0354 P 00000000
N0355 P 00000000
N0356 P 00000000
N0357 P 00000000
N0358 P 00000000
N0359 P 00000000
N0360 P 00000000
N0361 P 00000000
N0362 P 00000000
N0363 P 00000000
N0364 P 00000000
N0365 P 00000000
N0366 P 00000000
N0367 P 00000000
N0368 P 00000000
N0369 P 00000000
N0370 P 00000000
N0371 P 00000000
N0372 P 00000000
N0373 P 00000000
N0374 P 00000000
N0375 P 00000000
N0376 P 00000000
N0377 P 00000000
N0378 P 00000000
N0379 P 00000000
N0380 P 00000000
N0381 P 00000000
N0382 P 00000000
N0383 P 00000000
N0384 P 00000000
N0385 P 00000000
N0386 P 00000000
N0387 P 00000000
N0388 P 00000000
N0389 P 00000000
N0390 P 00000000
N0391 P 00000000
N0392 P 00000000
N0393 P 00000000
N0394 P 00000000
N0395 P 00000000
N0396 P 00000000
N0397 P 00000000
N0398 P 00000000
N0399 P 00000000
N0400 P 00000000
N0401 P 00000000
N0402 P 00000000
N0403 P 00000000
N0404 P 00000000
N0405 P 00000000
N0406 P 00000000
N0407 P 00000000
N0408 P 00000000
N0409 P 00000000
N0410 P 00000000
N0411 P 00000000
N0412 P 00000000
N0413 P 00000000
N0414 P 00000000
N0415 P 00000000
N0416 P 00000000
N0417 P 00000000
N0418 P 00000000
N0419 P 00000000
N0420 P 00000000
N0421 P 00000000
N0422 P 00000000
N0423 P 00000000
N0424 P 00000000
N0425 P 00000000
N0426 P 00000000
N0427 P 00000000
N0428 P 00000000
N0429 P 00000000
N0430 P 00000000
N0431 P 00000000
N0432 P 00000000
N0433 P 00000000
N0434 P 00000000
N0435 P 00000000
N0436 P 00000000
N0437 P 00000000
N0438 P 00000000
N0439 P 00000000
N0440 P 00000000
N0441 P 00000000
N0442 P 00000000
N0443 P 00000000
N0444 P 00000000
N0445 P 00000000
N0446 P 00000000
N0447 P 00000000
N0448 P 00000000
N0449 P 00000000
N0450 P 00000000
N0451 P 00000000
N0452 P 00000000
N0453 P 00000000
N0454 P 00000000
N0455 P 00000000
N0456 P 00000000
N0457 P 00000000
N0458 P 00000000
N0459 P 00000000
N0460 P 00000000
N0461 P 00000000
N0462 P 00000000
N0463 P 00000000
N0464 P 00000000
N0465 P 00000000
N0466 P 00000000
N0467 P 00000000
N0468 P 00000000
N0469 P 00000000
N0470 P 00000000
N0471 P 00000000
N0472 P 00000000
N0473 P 00000000
N0474 P 00000000
N0475 P 00000000
N0476 P 00000000
N0477 P 00000000
N0478 P 00000000
N0479 P 00000000
N0480 P 00000000
N0481 P 00000000
N0482 P 00000000
N0483 P 00000000
N0484 P 00000000
N0485 P 00000000
N0486 P 00000000
N0487 P 00000000
N0488 P 00000000
N0489 P 00000000
N0490 P 00000000
N0491 P 00000000
N0492 P 00000000
N0493 P 00000000
N0494 P 00000000
N0495 P 00000000
N0496 P 00000000
N0497 P 00000000
N0498 P 00000000
N0499 P 00000000
N0500 P 00000020
N0501 P 00000020
N0502 P 00000020
N0503 P 00000020
N0504 P 00008333
N0505 P 00008333
N0506 P 00008333
N0507 P 00008333
N0508 P 00000000
N0509 P 00000000
N0510 P 00000000
N0511 P 00000000
N0512 P 00000000
N0513 P 00000000
N0514 P 00000000
N0515 P 00000000
N0516 P 00001000
N0517 P 00003000
N0518 P 00005000
N0519 P 00005000
N0520 P 00005000
N0521 P 00005000
N0522 P 00000200
N0523 P 00000200
N0524 P 00000200
N0525 P 00000200
N0526 P 00000000
N0527 P 00002000
N0528 P 00000000
N0529 P 00000025
N0530 P 00001000
N0531 P 00000000
N0532 P 00000000
N0533 P 00000000
N0534 P 00000250
N0535 P 00000060
N0536 P 00000040
N0537 P 00000060
N0538 P 00000000
N0539 P 00004000
N0540 P 00004000
N0541 P 00004000
N0542 P 00004000
N0543 P 00000050
N0544 P 00000008
N0545 P-00000015
N0546 P-00000003
N0547 P 00000000
N0548 P 00005000
N0549 P 00000000
N0550 P 00000010
N0551 P 00000000
N0552 P 00000010
N0553 P 00000006
N0554 P 00000000
N0555 P 00002900
N0556 P 00000500
N0557 P 00000000
N0558 P 00000200
N0559 P 00000000
N0560 P 00000000
N0561 P 00000000
N0562 P 00000000
N0563 P 00000000
N0564 P 00000000
N0565 P 00000000
N0566 P 00000000
N0567 P 00000000
N0568 P 00000000
N0569 P 00000000
N0570 P 00000000
N0571 P 00000000
N0572 P 00000000
N0573 P 00000000
N0574 P 00000000
N0575 P 00000000
N0576 P 00000000
N0577 P 00000000
N0578 P 00000000
N0579 P 00000000
N0580 P 00000000
N0581 P 00000000
N0582 P 00000000
N0583 P 00000000
N0584 P 00000000
N0585 P 00000000
N0586 P 00000000
N0587 P 00000000
N0588 P 00000000
N0589 P 00000000
N0590 P 00000000
N0591 P 00000000
N0592 P 00000000
N0593 P 00000100
N0594 P 00000100
N0595 P 00000100
N0596 P 00000100
N0597 P 00000000
N0598 P 00000000
N0599 P 00000000
N0600 P 00000000
N0601 P 00000000
N0602 P 00000000
N0603 P 00000000
N0604 P 00000000
N0605 P 00000000
N0606 P 00000000
N0607 P 00000000
N0608 P 00000000
N0609 P 00000000
N0610 P 00000000
N0611 P 00000000
N0612 P 00000000
N0613 P 00000000
N0614 P 00000000
N0615 P 00000000
N0616 P 00000000
N0617 P 00000000
N0618 P 00000000
N0619 P 00000000
N0620 P 00000000
N0621 P 00000000
N0622 P 00000000
N0623 P 00000000
N0624 P 00000000
N0625 P 00000000
N0626 P 00000000
N0627 P 00000000
N0628 P 00000000
N0629 P 00000000
N0630 P 00000000
N0631 P 00000000
N0632 P 00000000
N0633 P 00000000
N0634 P 00000000
N0635 P 00000000
N0636 P 00000000
N0637 P 00000000
N0638 P 00000000
N0639 P 00000000
N0640 P 00000000
N0641 P 00000000
N0642 P 00000000
N0643 P 00000000
N0644 P 00000000
N0645 P 00000000
N0646 P 00000000
N0647 P 00000000
N0648 P 00000000
N0649 P 00000000
N0650 P 00000000
N0651 P 00000000
N0652 P 00000000
N0653 P 00000000
N0654 P 00000000
N0655 P 00000000
N0656 P 00000000
N0657 P 00000000
N0658 P 00000000
N0659 P 00000000
N0660 P 00000000
N0661 P 00000000
N0662 P 00000000
N0663 P 00000000
N0664 P 00000000
N0665 P 00000000
N0666 P 00000000
N0667 P 00000000
N0668 P 00000000
N0669 P 00000000
N0670 P 00000000
N0671 P 00000000
N0672 P 00000000
N0673 P 00000000
N0674 P 00000000
N0675 P 00000000
N0676 P 00000000
N0677 P 00000000
N0678 P 00000000
N0679 P 00000000
N0680 P 00000000
N0681 P 00000000
N0682 P 00000000
N0683 P 00000000
N0684 P 00000000
N0685 P 00000000
N0686 P 00000000
N0687 P 00000000
N0688 P 00000000
N0689 P 00000000
N0690 P 00000000
N0691 P 00000000
N0692 P 00000000
N0693 P 00000000
N0694 P 00000000
N0695 P 00000000
N0696 P 00000000
N0697 P 00000000
N0698 P 00000000
N0699 P 00000000
N0700 P 00250000
N0701 P 00015000
N0702 P 00015000
N0703 P 99999999
N0704 P-00040000
N0705 P-00160000
N0706 P-00185000
N0707 P-09999999
N0708 P 00000000
N0709 P 00000000
N0710 P 00000000
N0711 P 00000000
N0712 P 00000000
N0713 P 00000000
N0714 P 00000000
N0715 P 00000000
N0716 P 00000000
N0717 P 00000000
N0718 P 00000000
N0719 P 00000000
N0720 P 00000000
N0721 P 00000000
N0722 P 00000000
N0723 P 00000000
N0724 P 00000000
N0725 P 00000000
N0726 P 00000000
N0727 P 00000000
N0728 P 00000000
N0729 P 00000000
N0730 P 00000000
N0731 P 00000000
N0732 P 00000000
N0733 P 00000000
N0734 P 00000000
N0735 P 00000000
N0736 P 00000000
N0737 P 00000000
N0738 P 00000000
N0739 P 00000000
N0740 P 00000000
N0741 P 00000000
N0742 P 00000000
N0743 P 00000000
N0744 P 00000000
N0745 P 00000000
N0746 P 00000000
N0747 P 00000000
N0748 P 00000000
N0749 P 00000000
N0750 P 00000000
N0751 P 00000000
N0752 P 00000000
N0753 P 00000000
N0754 P 00000000
N0755 P 00000000
N0756 P 00000000
N0757 P 00000000
N0758 P 00000000
N0759 P 00000000
N0760 P 00000000
N0761 P 00000000
N0762 P 00000000
N0763 P 00000000
N0764 P 00000000
N0765 P 00000000
N0766 P 00000000
N0767 P 00000000
N0768 P 00000000
N0769 P 00000000
N0770 P 00000000
N0771 P 00000000
N0772 P 00000000
N0773 P 00000000
N0774 P 00000000
N0775 P 00000000
N0776 P 00000000
N0777 P 00000000
N0778 P 00000000
N0779 P 00000030
N0780 P 00000000
N0781 P 00000000
N0782 P 00000000
N0783 P 00000000
N0784 P 00000000
N0785 P 00000000
N0786 P 00000000
N0787 P 00000000
N0788 P 00000000
N0789 P 00000000
N0790 P 00000000
N0791 P 00000000
N0792 P 00000000
N0793 P 00000000
N0794 P 00000000
N0795 P 00000000
N0796 P 00000000
N0797 P 00000000
N0798 P 00000000
N0799 P 00000000
N0800 P 00000000
N0801 P 00000000
N0802 P 00000000
N0803 P 00000000
N0804 P 00000000
N0805 P 00000000
N0806 P 00000000
N0807 P 00000000
N0808 P 00000000
N0809 P 00000000
N0810 P 00000000
N0811 P 00000000
N0812 P 00000000
N0813 P 00000000
N0814 P 00000000
N0815 P 00000000
N0816 P 00000000
N0817 P 00000000
N0818 P 00000000
N0819 P 00000000
N0820 P 00000000
N0821 P 00000000
N0822 P 00000000
N0823 P 00000000
N0824 P 00000000
N0825 P 00000000
N0826 P 00000000
N0827 P 00000000
N0828 P 00000000
N0829 P 00000000
N0830 P 00000000
N0831 P 00000000
N0832 P 00000000
N0833 P 00000000
N0834 P 00000000
N0835 P 00000000
N0836 P 00000000
N0837 P 00000000
N0838 P 00000000
N0839 P 00000000
N0840 P 00000000
N0841 P 00000000
N0842 P 00000000
N0843 P 00000000
N0844 P 00000000
N0845 P 00000000
N0846 P 00000000
N0847 P 00000000
N0848 P 00000000
N0849 P 00000000
N0850 P 00000000
N0851 P 00000000
N0852 P 00000000
N0853 P 00000000
N0854 P 00000000
N0855 P 00000000
N0856 P 00000000
N0857 P 00000000
N0858 P 00000000
N0859 P 00000000
N0860 P 00000000
N0861 P 00000000
N0862 P 00000000
N0863 P 00000000
N0864 P 00000000
N0865 P 00000000
N0866 P 00000000
N0867 P 00000000
N0868 P 00000000
N0869 P 00000000
N0870 P 00000000
N0871 P 00000000
N0872 P 00000000
N0873 P 00000000
N0874 P 00000000
N0875 P 00000000
N0876 P 00000000
N0877 P 00000000
N0878 P 00000000
N0879 P 00000000
N0940 P 00000000
N0941 P 00000000
N0942 P 00000000
N0943 P 00000000
N0944 P 00000000
N0945 P 00000000
N0946 P 00000000
N0947 P 00000000
N0948 P 00000000
N0949 P 00000000
N0950 P 00000000
N0951 P 00000000
N0952 P 00000000
N0953 P 00000000
N0954 P 00000000
N0955 P 00000000
N0956 P 00000000
N0957 P 00000000
N0958 P 00000000
N0959 P 00000000
N0960 P 00000000
N0961 P 00000000
N0962 P 00000000
N0963 P 00000000
N0964 P 00000000
N0965 P 00000000
N0966 P 00000000
N0967 P 00000000
N0968 P 00000000
N0969 P 00000000
N0970 P 00000000
N0971 P 00000000
N0972 P 00000000
N0973 P 00000000
N0974 P 00000000
N0975 P 00000000
N0976 P 00000000
N0977 P 00000000
N0978 P 00000000
N0979 P 00000000
N0980 P 00000000
N0981 P 00000000
N0982 P 00000000
N0983 P 00000000
N0984 P 00000000
N0985 P 00000000
N0986 P 00000000
N0987 P 00000000
N0988 P 00000000
N0989 P 00000000
N0990 P 00000000
N0991 P 00000000
N0992 P 00000000
N0993 P 00000000
N0994 P 00000000
N0995 P 00000000
N0996 P 00000000
N0997 P 00000000
N0998 P 00000000
N0999 P 00000000
N8100 P 00000010
N8101 P 00001101
N8102 P 00001000
N8103 P 00000000
N8104 P 01000110
N8105 P 00000000
N8106 P 00000000
N8107 P 00000000
N8108 P 00000000
N8109 P 00000000
N8110 P 00000000
N8111 P 00000000
N8112 P 00000000
N8113 P 00000000
N8114 P 00000000
N8115 P 00000000
N8116 P 00000000
N8117 P 00000000
N8118 P 00000000
N8119 P 00000000
N8120 P 00000045
N8121 P 00000000
N8122 P-00000111
N8123 P 00004000
N8124 P 00004000
N8125 P 00000000
N8126 P 00000000
N8127 P 00000000
N8128 P 00000000
N8129 P 00000000
N8130 P 00000000
N8131 P 00000000
N8132 P 00000000
N8133 P 00000000
N8134 P 00000000
N8135 P 00000000
N8136 P 00000000
N8137 P 00000000
N8138 P 00000000
N8139 P 00000000
N8140 P 00000390
N8141 P-00000810
N8142 P-00002480
N8143 P 00000111
N8144 P-00000997
N8145 P 00000000
N8146 P-00008235
N8147 P 00003806
N8148 P 00000000
N8149 P 00000000
N8150 P 00000956
N8151 P 00000510
N8152 P 00000000
N8153 P 00000021
N8154 P 00003787
N8155 P 00000319
N8156 P 00001589
N8157 P 00002330
N8158 P 00000057
N8159 P 00000000
N8160 P 00007282
N8161 P 00000120
N8162 P 00032623
N8163 P 00001811
N8164 P 00000004
N8165 P 00005377
N8166 P 00000000
N8167 P 00000000
N8168 P 00000000
N8169 P 00000000
N8170 P 00000000
N8171 P 00000000
N8172 P 00000000
N8173 P 00000000
N8174 P 00000000
N8175 P 00000000
N8176 P 00000000
N8177 P 00000000
N8178 P 00000000
N8179 P 00000000
N8180 P 00000000
N8181 P 00000000
N8182 P 00000000
N8183 P 00000000
N8184 P 00000000
N8185 P 00000000
N8186 P 00001706
N8187 P 00000000
N8188 P 00000000
N8189 P 00000000
N8190 P 00000000
N8191 P 00000000
N8192 P 00000000
N8193 P 00000000
N8194 P 00000000
N8195 P 00000000
N8196 P 00000000
N8197 P 00000000
N8198 P 00000000
N8199 P 00000000
N8200 P 00000010
N8201 P 00001101
N8202 P 00001000
N8203 P 00000000
N8204 P 01000110
N8205 P 00000000
N8206 P 00000000
N8207 P 00000000
N8208 P 00000000
N8209 P 00000000
N8210 P 00000000
N8211 P 00000000
N8212 P 00000000
N8213 P 00000000
N8214 P 00000000
N8215 P 00000000
N8216 P 00000000
N8217 P 00000000
N8218 P 00000000
N8219 P 00000000
N8220 P 00000045
N8221 P 00000000
N8222 P-00000111
N8223 P 00004000
N8224 P 00004000
N8225 P 00000000
N8226 P 00000000
N8227 P 00000000
N8228 P 00000000
N8229 P 00000000
N8230 P 00000000
N8231 P 00000000
N8232 P 00000000
N8233 P 00000000
N8234 P 00000000
N8235 P 00000000
N8236 P 00000000
N8237 P 00000000
N8238 P 00000000
N8239 P 00000000
N8240 P 00000390
N8241 P-00000810
N8242 P-00002480
N8243 P 00000111
N8244 P-00000997
N8245 P 00000000
N8246 P-00008235
N8247 P 00003806
N8248 P 00000000
N8249 P 00000000
N8250 P 00000956
N8251 P 00000510
N8252 P 00000000
N8253 P 00000021
N8254 P 00003787
N8255 P 00000319
N8256 P 00001589
N8257 P 00002330
N8258 P 00000057
N8259 P 00000000
N8260 P 00007282
N8261 P 00000120
N8262 P 00032623
N8263 P 00001811
N8264 P 00000004
N8265 P 00005377
N8266 P 00000000
N8267 P 00000000
N8268 P 00000000
N8269 P 00000000
N8270 P 00000000
N8271 P 00000000
N8272 P 00000000
N8273 P 00000000
N8274 P 00000000
N8275 P 00000000
N8276 P 00000000
N8277 P 00000000
N8278 P 00000000
N8279 P 00000000
N8280 P 00000000
N8281 P 00000000
N8282 P 00000000
N8283 P 00000000
N8284 P 00000000
N8285 P 00000000
N8286 P 00001706
N8287 P 00000000
N8288 P 00000000
N8289 P 00000000
N8290 P 00000000
N8291 P 00000000
N8292 P 00000000
N8293 P 00000000
N8294 P 00000000
N8295 P 00000000
N8296 P 00000000
N8297 P 00000000
N8298 P 00000000
N8299 P 00000000
N8300 P 00000010
N8301 P 00001101
N8302 P 00001000
N8303 P 00000000
N8304 P 01000110
N8305 P 00000000
N8306 P 00000000
N8307 P 00000000
N8308 P 00000000
N8309 P 00000000
N8310 P 00000000
N8311 P 00000000
N8312 P 00000000
N8313 P 00000000
N8314 P 00000000
N8315 P 00000000
N8316 P 00000000
N8317 P 00000000
N8318 P 00000000
N8319 P 00000000
N8320 P 00000045
N8321 P 00000000
N8322 P-00000111
N8323 P 00004000
N8324 P 00004000
N8325 P 00000000
N8326 P 00000000
N8327 P 00000000
N8328 P 00000000
N8329 P 00000000
N8330 P 00000000
N8331 P 00000000
N8332 P 00000000
N8333 P 00000000
N8334 P 00000000
N8335 P 00000000
N8336 P 00000000
N8337 P 00000000
N8338 P 00000000
N8339 P 00000000
N8340 P 00000390
N8341 P-00000810
N8342 P-00002480
N8343 P 00000111
N8344 P-00000997
N8345 P 00000000
N8346 P-00008235
N8347 P 00003806
N8348 P 00000000
N8349 P 00000000
N8350 P 00000956
N8351 P 00000510
N8352 P 00000000
N8353 P 00000021
N8354 P 00003787
N8355 P 00000319
N8356 P 00001589
N8357 P 00002330
N8358 P 00000057
N8359 P 00000000
N8360 P 00007282
N8361 P 00000120
N8362 P 00032623
N8363 P 00001811
N8364 P 00000004
N8365 P 00005377
N8366 P 00000000
N8367 P 00000000
N8368 P 00000000
N8369 P 00000000
N8370 P 00000000
N8371 P 00000000
N8372 P 00000000
N8373 P 00000000
N8374 P 00000000
N8375 P 00000000
N8376 P 00000000
N8377 P 00000000
N8378 P 00000000
N8379 P 00000000
N8380 P 00000000
N8381 P 00000000
N8382 P 00000000
N8383 P 00000000
N8384 P 00000000
N8385 P 00000000
N8386 P 00001706
N8387 P 00000000
N8388 P 00000000
N8389 P 00000000
N8390 P 00000000
N8391 P 00000000
N8392 P 00000000
N8393 P 00000000
N8394 P 00000000
N8395 P 00000000
N8396 P 00000000
N8397 P 00000000
N8398 P 00000000
N8399 P 00000000
masroorkhan
Post by masroorkhan » Wed 25 Mar , 2015 15:53 pm
ok sir i will check these parameter on machine tomorrow they are different then the one i have downloaded from net.
also sir you send me the machine info yesterday in that the motor model is AO6B-0371-B010#7000
and driver model is AO6B-6058-H331.
is this (AO6B-0371-B010#7000 ) motor model is 2-osp,10,000 pulse encoders too.
sir yesterday you send me the 900 parameter and 700 to 708 parameter and diagnostics parameter 450 to 458
but sir what about the other parameter. do they not machine and motor specific.
Post by Martin » Wed 25 Mar , 2015 16:39 pm
I think your machine is fitted with Fanuc 2-osp servo motors.
The 700 & 900 parameters & 450 diagnostics need to be set also as from the data sheet provided yesterday. That was how it would have left the factory.
masroorkhan
Post by masroorkhan » Wed 25 Mar , 2015 17:46 pm
sir is there any way to confirm it from motor model number (AO6B-0371-B010#7000 ) which fanuc osp servo motor it is.
i just check in the given two link that given servo motor model (AO6B-0371-B010#7000 ) is 2-osp
but in one link it say it is fitted with a 2500 pulse coder is it a standard or the pulse coder doesn't matter.
if plus coder matter then what should i change in parameter.
https://cnc-electronics.com/fanuc-parts/ ... 0371-b010/
https://www.ebay.com/itm/GE-FANUC-A06B-0 ... 1214710315
masroorkhan
Post by masroorkhan » Thu 26 Mar , 2015 14:01 pm
thank you sir martin all alarm are clear now the machine is running now with new parameter for 2-osp servo motor.
its a good learning process journey with you sir.
sir are you den ford employ?
thanks again for your cooperation.
Post by Martin » Thu 26 Mar , 2015 15:07 pm
Yes I work at Denfords in the UK. Production Manager & Service Engineer.
Good to hear you are up & running again.
