Spindle stalling at max RPM without being under load
SamD
Hardware/Software: -
Hardware:
- Denford Starmill P.C. Non-ATC (Dec 1993)
- DIYCNC.co.uk Uniport V2 Breakout Board
- DIYCNC.co.uk Spindle V3 Board
- UC100 USB CNC Motion Controller
Software:
- Mach3 R3.043 on Windows 7
- CamBam Plus V1.0
Post by SamD » Thu 27 Feb , 2025 13:51 pm
Hello all,
I am having a problem with the spindle speed on my 1994 Starmill PC, running on Mach 3.
In short, if I run the spindle at max RPM (3000), after a few minutes of running, it stalls. Even when not under load.
I have also noticed that the speed is varying (hunting) when at max RPM.
If I run it at 2500 RPM, there is no problem. I have verified the RPM with an external laser tacho.
I have removed, inspected and, cleaned both the brushes (which looked totally fine), and the commutator on the motor, with no effect.
I have re-greased the spindle bearings, and it turns freely.
I am wondering if the problem is with the Sprint drive or the interface with Mach 3. The Mach 3 controller communicates via a DIYCNC breakout board and a DIYCNC spindle board.
With regards to the spindle RPM on Mach 3; generally what I ask for is what I get. 1000 RPM equals an actual of around 970 RPM. 3000 RPM equals around 2900 RPM.
I was considering fiddling with the MIN, MAX and CURRENT pots on the sprint drive to see if that has any effect, but I am nervous about that.
This machine has had very little use before it was converted by someone else to Mach 3. I have run it for probably 12 hours, most of which at 3000 RPM for some engraving work, and not had a problem until recently, now I can’t run it over 2500 RPM for fear of the spindle stopping mid cut.
Any tips are welcome! Thank you.
:roll:
