Starmill Stepper Motor Questions
Posted: Tue 12 Jan , 2010 15:53 pm
Hi all, I am looking for some advice regarding the possibility of replacing my stepper motors.
A short while ago I had an issue with my Y axis wandering because my Starmill couldn't cope with running at higher speeds:
(viewtopic.php?f=2&t=2380&p=8636&hilit=w ... axis#p8636)
I now have a problem where both my X and Y axis are failing to achieve their target values. For example if the cutter should be moving to X10, Y10 it may make it as far as X8, Y9 and just carry on to the next line of code. Over the period of a few lines the tool is nowhere near where it should be. The machine is well lubricated and the gib strip adjustments seem to be fine.
However when I used my lathe the other day I noticed that I could feel increased resistance (compared to normal) when moving the tool in both the X and Y axis. I think this is because it is so cold in my garage at the moment. Its poorly insulated and we've been seeing -10degC at night.
Based on this I wonder if my starmill is failing to achieve its target values because the cold is having the same effect on the mill as it is on the lathe, with the increased resistance being too much for the stepper motors?
I am therefore now begining to consider replacing my stepper motors. If nothing else it would be nice if I could machine things a bit quicker without the machine stalling/losing position.
I am wondering what is the best way to go about doing this? My plan was to examine the existing motors and try to find equivalent replacements, or better still, suitable upgrades. Can I just undo the fixing's circled in the attached picture and try and find a part number or will removing the motor in this way cause any kind of calibration error?
Any suggestions or guidance on this would be great!
