Starmill Rotary Table Size Sugestions?
Posted: Mon 06 Oct , 2008 18:59 pm
by paragon
Hello Group,
What size rotary table would you recommend for the Denford Starmill?
I was thinking of a Vertex HV4 (100 mm) but I think it maybe to big?
Any sugestions?
Thanks,
SRG
Posted: Tue 07 Oct , 2008 13:42 pm
by SimonRafferty
A small one!
Why do you need a rotary table - since you can interpolate any hole size and use the existing axes to do pretty much anything a rotary table can do?
I can see using an indexing head as an additional axis - so maybe you mean using it with the axis horizontal?
Si
Posted: Wed 08 Oct , 2008 13:27 pm
by paragon
Thank You for your reply Simon.
The table will be used for a fourth axis.
I decided to go for this table due to the Z axis limitation of the Starmill (115mm) with the intention of converting to CNC (servo / stepper undecided)
https://cgi.ebay.co.uk/HMB-100MM-ROTARY- ... 286.c0.m14
The Starmill Setup in case anyone is interested :-)
I have converted the mill to use EMC2 and have upgraded the stepper motors to double stacked and motion control stepper drives.
https://www.motioncontrolproducts.co.uk/ ... ducts_id=2
The mill rapids are approx 1800mm per minute which is limited only buy the step / dir pulses sent to the para port.
Looking to upgrade to a Messa 7i43 card to improve micro stepping and velocity.
Will be posting images shortly.
Cheers,
Posted: Wed 08 Oct , 2008 13:50 pm
by SimonRafferty
That looks ideal! Particularly with the Myford chuck adaptor - you could do just about anything!
Si
