Starmill - ATC - Compressor
andy_con
Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
Post by andy_con » Sun 18 Aug , 2013 18:16 pm
just looked in the starmill manual and it say if the air pressure drops before 90 B.P.I. the atc will stop working.
what is 90 bpi?
would this compressor run the atc?
https://www.ebay.co.uk/itm/241183-Silent ... 43be02c5d5
Re: Starmill - ATC - Compressor
Post by Martin » Mon 19 Aug , 2013 14:01 pm
I presume it should read psi?
90 psi = 6.21 Bar.
We used to set them to run between 80 to 100 psi so the compressor should be fine.
andy_con
Starmills with ATC
Post by andy_con » Mon 19 Aug , 2013 20:59 pm
oh right I see thanks
