Orac RS232 almost a problem??
Posted: Sat 23 Sep , 2006 4:05 am
I have written a template converter/nc creator for the orac to use with EDGECam, and all is good, the code generated works perfect, if i enter it manually into the the ORAC, but fails to work when i send it via the serial port.
The setup is fine, and i can both send and recieve files to the ORAC over the serial cable.
I believe that the problem is the control characters, in the manual im sure it said that a program has to start with a control character, then each block starts, and ends with a control character, then the program ends with a control character.
I no longer have the manual for the orac, so can anyone tell me what control characters i need to use, i believe they are STX RS EOF and something else, but the orac rejects the program, so if someone could fill in the blanks that be great.
Once i have it sussed, if anyone else uses edgecam, then feel free to pm me and i'll send you the template (for use at your own risk)
On a side not, as soon as i have my ORAC's sorted, i need to make the converter for the Triac, and i have never had a manual for this, or even seen one, so if anyone has a copy of that, or could scan it or whatever, id greatly appreciate it.
Graham
Graham
