hi to all
i am in process of sorting out an orac
whilst getting to know how machine works i have been doing some basic turning
when cutting along the z axis the work piece diameter reduces by approx 2 thou over 3/4 "
were should i start to rectify this
cheers bert
orac headstock out of adjustment
hi admin
i was cutting some black nylon at about 5 mm
it might have been deflection
have got imp dti on mag mount
re tried with some hex brass with aprox 3" from chuck with out tail stock ( unable to garantee accuracy of tail stock ) this showed 2 thou other 2"
before i go further i must get some ground bar
have spotted adjusment location on back of headstock i will not touch this untill i realy have to
if i do have to adjust what is correct procedeure for both head and tail
cheers bert
cheers bert
Hi - sorry but I've asked around and it would seem that kind of machine setup has never been documented - its the sort of thing that gets done when the machine is built, and should never need adjusting (unless of course you crash the machine)
With the Orac the Z axis was setup parallel first, then the X was also thrown so that it ran square to the Z.
I'd hope that your problem will just need the Z resetting by throwing the headstock:
If you don't have a ground test bar, then you could try this procedure:
do a long cut on a test piece,
measure the taper,
put the clock on the far end of the test piece,
loosen the 4 headstock screws slightly,
tap the headstock around until the clock moves half of the taper amount - which way to go will depend whether its cutting big or small at the end.,
tighten and try the test cut again..
you may also find that your centreline will have shifted, so re-check your offsets.
HTH
measure the taper,
HTH
