How do I get started with GCODE for Novaturn/FLSTEP?
Posted: Fri 06 Nov , 2009 22:32 pm
by torleifj
Hi.
I have a list of gcodes in the lathe manual, but no specification of parameters. Where are the parameters documented? Is there a demo CAM package that will generate valid gcode for the Novaturn?
/Torleif.
Re: How do I get started with GCODE for Novaturn/FLSTEP?
Posted: Mon 09 Nov , 2009 12:06 pm
Hmm, I have had a look through the manuals we have here, and see your problem - they only contain lists of the G codes without listing the parameters.
Maybe these will help anyway:
viewtopic.php?f=15&t=2324
viewtopic.php?f=15&t=953
It could be that the only help is from within the software, if you look at the FLSTEP.MSG in a text editor, I see that there is some help information about the G codes in there
Posted: Mon 09 Nov , 2009 19:29 pm
by torleifj
Thanks for your help.
I had missed the fact that the G/M codes are documented in FLSTEP. I assume that the help text in FLSTEP.exe is read from FLSTEP.msg
/Torleif.
Posted: Tue 10 Nov , 2009 10:35 am
I believe so yes
