Novaturn spindle speed unstable
torleifj
Post by torleifj » Thu 05 Nov , 2009 23:59 pm
Hi.
I finally got my Novaturn (DOS/FLSTEP) up and running. It was 100% strightforward, so I have no excuses for not having done it a year ago except time. Being an absolute novice with the Novaturn, I don't know what to expect, so I have 2 questions:
At 100RPM, the spindle speed is unstable, it oscillates between 90RPM and 110RPM. Is there a setting, I should know about?
When I press spindle CCW, nothing happens. Is this a problem with my Novaturn, or is that the way they are? Or is it an option, a relay or something?
Best regards,
Torleif.
Re: Novaturn spindle speed unstable
Post by Martin » Sun 08 Nov , 2009 20:13 pm
The spindle speeds normally flucutate slightly at low rpm up to around 250 rpm. Try running at higer rpm`s to test it.
The spindle on the Novaturn will only run in one direction.
torleifj
Post by torleifj » Sun 08 Nov , 2009 20:42 pm
Thanks!
I will then search no more.
/Torleif.
