NovaMill X-axis Motor grinding noise
boots
Post by boots » Wed 07 Mar , 2007 17:24 pm
The X axis is giving me problems. Y and Z are fine. When homing all the X gets to 0 and then keeps trying to move with a bad sound. The computer continues to count but the machine can not move any further. Seems like a limit switch.
When jogging the x axis the machine does not correctly move with the arrows. When I hit the left arrow, sometimes it goes left. Other times it goes right. When you hold it down sometimes it goes left for a little while then right and so on.
The programs are no longer running correctly with this issue.
Post by bradders » Thu 08 Mar , 2007 12:43 pm
Usually if the axes are running the wrong way to the keyboard presses, then it could be a broken or loose wire.
When homing the X axis the motor makes a grinding noise, usally means the the datum switch activation bolt on the X axis carriage is at the wrong side of the datum switch. Try the secret button (See link below) and jog the X axis to the left of the machine and try to re home
viewtopic.php?p=104#104
Post by Denford Admin » Thu 08 Mar , 2007 16:21 pm
I think the stepper drive is faulty, or wiring to the X stepper motor is faulty.
It sounds like it isn't homing properly because its not able to change directions properly
You can rule in or out the wiring by swapping the X and Y motor plugs
boots
Post by boots » Thu 08 Mar , 2007 17:58 pm
Loose yellow wire at X-axis drive socket on control card.
Thanks for the help :wink:
