Novamill Part names
oyoung
Hardware/Software: Quickcam Pro v1.13.0.76
VR Milling v5.63.0.680
Novamill
Microrouter Pro
Win 7 Pro
Novamill Part names
Post by oyoung » Wed 30 May , 2012 14:57 pm
Hi Can someone please clarify which part is the 'Headstock' and which part is the 'Axis Bearings'?
I am trying to maintain/lubricate the thing. Is 'Headstock' the main spindle? Presumably the spindle and the spindle motor have bearings that will both need renewing after several miles of wear?
Are the 'Axis Bearings' the X,Y and Z motor bearings?
When the spindle spins it makes a bit of a grinding noise. I guess it's new bearing time...
Re: Novamill Part names
Post by Denford Admin » Wed 30 May , 2012 15:14 pm
To me, headstock is usually the bit that turns the chuck on a lathe...normally Headstock on the left, Tailstock on the right.
On a mill, the "headstock" would equate to what I know as the spindle (the bit that spins the tools)
Axis bearings will mean the axis leadscrew end-bearings. An axis "nut" is the thing that goes around the leadscrew to move the axis...it will contain small ball bearings that usually need some lubricating.
Novamill Milling Spindle Head Arrangement Drawings
viewtopic.php?t=1785
Denford Starmill(Novamill) Spindle Bearing
viewtopic.php?f=45&t=712
oyoung
Novamill
Microrouter Pro
Win 7 Pro
Post by oyoung » Wed 30 May , 2012 22:45 pm
I took the thing apart and it seemed, according to this download/file.php?id=766 that part RM1/715A has become slightly bent at the top and rotates with a slight wobble, if that's the technical term. It fouls on part RM7/105 and that's what is growling. I gave it a seeing to with a file and it's fine now.
Thanks very much :D
PS: Correct file link now added :oops: :lol:
Post by Denford Admin » Thu 31 May , 2012 8:47 am
Glad it's fixed :)
For anyone else looking, is RM7/105 the tin lid ? I can't see it on that drawing..
