Novamill, Mach 3 and UIM2901-5A BoB
Posted: Fri 27 Apr , 2012 15:31 pm
I have just acquired a Novamill, with Electronics and am looking at conversion to Mach3.
The existing Electronics have a Denstep Controller (shows as D281 with V2.1 firmware - shows s/n 0C00271100 label on the processor) atop a Baldor F391 Optimised Control - s/n 0C00270971 - for the Stepper drives, and a Sprint 400 Spindle Driver board. (The machine has no information label with Model - Serial No - Date etc... on it - looks like it has been removed from the side of the Electronics box).
As I have no software associated with the machine, I was looking at my best options, and it seems that the MACH3 route is the favoured way forward - I can't afford to upgrade the controller to v5 software and board change. So I have looked into what I might need to do to the beast to get it running with MACH3.
It seems from other's writing on the forum that it would be feasible to remove the Denstep controller, and utilise a breakout board connected through pins on the 96 way DIN connector for the steppers (seems these pins are identified), and also the Spindle, and the datum switches - not sure I have found these pins yet on the 96 way DIN.
In looking at Breakout boards, it seems the UIM2901-5A Mach3 BoB is a possibility, offering Stepper and Spindle control - not sure what to do with the Datum's on it at this stage.
Has any one any experience of this BoB, and whether it is feasible to do what I want - which is a low cost conversion using as much of the Electronics as I can ?
Any input would be gratefully received.
ManxAnts
ManxAnts
