Novamill spindle drive motor
JohnHaine
Hardware/Software: My Novamill, bought in Nov 11 without electronics, is now up and running under Mach3 with a home-build control box. I'm very pleased with the machine, only project so far is correcting a cheap small machine vice originally bought for a vertical slide to use on the machine - not a right-angle in it when bought!
Post by JohnHaine » Mon 21 Nov , 2011 14:36 pm
Hi, I have acquired a Novamill which is without its control box. This is not necessarily a problem though as I have an exisiting set of drive electronics for my CNC lathe which with an extra axis will do the trick. HOWEVER, I will need a power supply for the spindle drive motor. I also have a DC motor driver which might do the job - can anyone tell me what the motor specification is please?
John.
Re: Novamill spindle drive motor
Post by Denford Admin » Wed 23 Nov , 2011 9:30 am
If you have the serial number of the machine (eg H001234 or E01234) then we can say for sure but i think it'll be an SEM motor:
viewtopic.php?f=4&t=2540
Post by Denford Admin » Wed 23 Nov , 2011 9:48 am
Sorry, just looked at a few novamill spec sheets and they say this:
Model S/no Volts kw Hz Ac/Dc Phase
BALDOR 5000RPM 180 .37 - DC -
The drive would have been a Sprint 400
viewtopic.php?t=634
JohnHaine
Post by JohnHaine » Wed 23 Nov , 2011 12:01 pm
Excellent, just what I need, thanks!
flyingmike
Post by flyingmike » Fri 30 Dec , 2011 22:48 pm
Check out Axis contols in Southport for KB electronics.
https://www.axiscontrols.co.uk/default.aspx
JohnHaine
Post by JohnHaine » Sat 31 Dec , 2011 18:30 pm
Mike, thanks for the link. Actually, the driver that I have is a KB one that I bought several years ago with a nice DC servo motor but never got round to using...and just a few minutes ago I fired it up and it drives the motor beautifully.
Cheers, John.
