Novamill Spindle wont turn!!! Please help
jcooke
Hardware/Software: Novamill using denford fanuc milling v 2.95
Post by jcooke » Thu 03 Mar , 2011 11:05 am
Hello there,
I purchased a Novamill awhile back but due to illness have only just got round to powering it up again, everything seems to work fine, I have it running Denford fanuc milling v2.95 (mint 3.28) under dos and it connects to the machine, allows me to jog all the axes but when I attempt to switch on the spindle, I can hear the cover guard lock clicking but that's all the spindle doesn't turn. It used to turn when I got the machine but I haven't done anything with it.
All the fuses inside the control box seem fine and the SGR relay trips on when I attempt to start the spindle at about 200revs.
The power light is on on the spindle control board.
Any ideas on how to check whether its the spindle motor / spindle control card / or something to do with the guard lock.
Many thanks James :dumbfounded:
Re: Novamill Spindle wont turn!!! Please help
Post by Denford Admin » Thu 03 Mar , 2011 11:57 am
Does it turn freely by hand ?
And have you checked the motor brushes ?
Post by Denford Admin » Thu 03 Mar , 2011 12:07 pm
Also have a look through the electrical schematics I've added to here:
viewtopic.php?f=41&t=2628
jcooke
Post by jcooke » Thu 03 Mar , 2011 12:18 pm
Hi there,
Many thanks for your reply,
I have checked the spindle turns freely by hand. i haven't checked the brushes , im not sure how to and I am not sure where to measure that Im getting 240v to the spindle. I've checked fuse1 and the fuse in the spindle board and both seem fine. ( not sure which wires are L and N). I bridged pins 4 and 5 on the spindle drive but this doesn't make any difference.
My thoughts are in the direction of emergency stop button / door guard or spindle brushes /spindle belt however I'm new to these machines and don't want to try anything stupid.
Please help!!!!
thanks James
jcooke
Post by jcooke » Thu 03 Mar , 2011 14:03 pm
Hi there,
Just sorted the problem, when moving the machine, I was somewhat heavy handed in attaching the umbilical cord and succeeded in bending pins 22 and 23, these control the spindle motor, simply a matter of powering down fixing the bent pins and the Novamill is dancing.
Thanks once again to Denford for offering support to a 1996 machine and keeping it running!!!!!!
