Novamill help needed
Posted: Fri 11 Jan , 2008 10:18 am
by janine
We have had this machine for over 8 years it has an eprom chip of 2.1, we are currently trying to use the DOS version on the software but due to a high changeover of staff non of us have the knowledge to test the machine.
If anyone could instruct me on testing it that would be great we would also like a bit of information regarding upgrading it to a windows version.
Posted: Fri 11 Jan , 2008 11:31 am
by Steve
Unfortunatley we can no longer support the DOS software though you may get some help on the forum.
The advantages of upgrading are covered on this forum. The best link is below.
viewtopic.php?t=116
I think if you try to run the machine in DOS you will only end up frustrated where upgrading to VR milling 5 will make the machien much simpler to use and more versatile as well as been compatable with modern PC's.
Good Luck :!:
Posted: Fri 11 Jan , 2008 15:40 pm
by janine
I have upgraded to 2.31 software recommended by denford now it gets to 66% on locating mint on com 1 any suggestions?
Also when I go to select the machine the Novamill is not an option.
Posted: Fri 11 Jan , 2008 17:52 pm
by Steve
Go to setup machine paramiters.
Then type the password "denny"
See the attached screens that show the machine choices in VR Milling.
Select NovaMill (Not NS) :!:
The right click and make the machien active.
Posted: Tue 15 Jan , 2008 16:03 pm
by janine
I've done all the above and now it's stuck on 0%
any more suggestions?
Posted: Tue 15 Jan , 2008 18:16 pm
by Steve
Having just spoken with you your machine is now up and running! :D
The option of VR Milling 5 would be good as you would get the DXF import.
Let us know how you get on.
Posted: Tue 15 Jan , 2008 18:43 pm
by janine
Machine looks all fine, I'm missing the denlcal.exe but the following link no longer works
https://www.denfordata.com/downloads/DENLCALL.EXE
Posted: Wed 16 Jan , 2008 10:23 am
by Steve
Will ask Admin to fix :!:
Posted: Wed 16 Jan , 2008 10:38 am
by Steve
Zipped file now posted. :D
Please visit link below.
viewtopic.php?t=678&highlight=
or get it direct here:
https://www.denfordata.com/downloads/DENLCALL.zip
