Novamill VR milling 5 (version 5.14). Offsets/homing probs
deannelord
Post by deannelord » Wed 05 Dec , 2007 15:40 pm
Post subject: Novamill VR milling 5 (version 5.14). Offsets/homing probs
In a fit of speedy working last week, I accidentally pressed Set x,y,z datum to 0 at current positions whilst only trying to adjust the z setting. At the time the machine was in its 'home' position.
As a result the machine is stuck in the home position. I have tried to restart the machine but it is still trapped at home. When I try to override and jog the machine into the correct position the machine will not do anything. The digits on screen change when home is pressed, and the following message appears:
Homing Error
Machine Error: Axes did not home out within 55.000 seconds you may jog the machine to find the problem.
There is no debris to obstruct any movement, but I cannot even jog the machine in any direction. Currently the settings read x=226.175, y=0.000, z=459.515.
Please help the Novamill and me have always been such good pals until now, Thanks.
Post by Martin » Wed 05 Dec , 2007 16:31 pm
Are the drives powered up?
Try using the secret home button,
viewtopic.php?t=53&highlight=secret
It may be worth checking the fuse on the control card.
