Pausing between blocks
Posted: Wed 08 Apr , 2020 20:58 pm
My mirac pc pauses between each block of code.
For example, if the program was to read:
N010 G01 X15 Z0
N015 G01 X15 Z-5
N020 G01 X15 Z-20
Then the feed would pause for a considerable time at Z-5 leaving a gouge in the workpiece as it chatters.
( I know you would not normally use such a code as above but it's just for illustration)
I have seen this issue before in milling, where the solution was to use G64. But the miracle doesn't recognise it.
I believe it is a denstep board but can't be sure, I'm not able to get access to the box to check.
Anyone come across this before?
N010 G01 X15 Z0
N015 G01 X15 Z-5
N020 G01 X15 Z-20
