Graphtec CE3000-60
Su Colman
Graphtec CE3000-60
Post by Su Colman » Tue 12 Dec , 2006 22:29 pm
I'm getting a Y-axis error message on start-up - any ideas why?
SJC
Post by Denford Admin » Wed 13 Dec , 2006 10:29 am
Personally, I've never used one, but others may be able to help....
Whats the error message saying ?
Su Colman
Graphtec
Post by Su Colman » Wed 13 Dec , 2006 16:58 pm
Error message says "y position alarm"
SJC
Su Colman
problem solved
Post by Su Colman » Wed 13 Dec , 2006 18:11 pm
I have got the solution to my problem
SJC
Post by Denford Admin » Wed 13 Dec , 2006 21:00 pm
Good news :)
Sorry things are a bit slack at the moment - everyone seems to be taking their holidays at once.
Would you mind posting the solution for us ? Just in case anyone else has the same thing in the future
Su Colman
Solution to "y position alarm" on Graphtec CE-3000
Post by Su Colman » Thu 14 Dec , 2006 0:02 am
There is a plate under the top cover, which breaks a sensor beam on the cutter as it moves to the zero zero point. When I took the top off, I could bend the plate back into place so as the cutter head moved, the sensor beam was broken, rather than the whole head running into the plate.
The problem was "probably" caused by a student leaning on the top of the machine.
SJC
